yungupgrade Posted May 17, 2022 Share Posted May 17, 2022 My gas pedal is sunken pretty far down into the floor and I'm not sure there's any way to adjust them so there's less slack in the line. I found a replacement cable on rock auto which I linked here but it looks like there's just as much slack between the distances of the bolts. Is that much distance in the line normal? https://www.rockauto.com/en/moreinfo.php?pk=65254&cc=1181584&pt=5892&jsn=10881 Link to comment Share on other sites More sharing options...
yungupgrade Posted May 17, 2022 Author Share Posted May 17, 2022 I added a pic of the pedals for reference. In all my other cars the gas is always slightly lower than the brake but in my MJ its the deepest on any vehicle I've ever driven. Not sure if it's supposed to be like that. Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 18, 2022 Share Posted May 18, 2022 I put a zip tie or two behind the end where it goes through the pedal. This moved the pedal out and really where I wanted it. The one thing that took me a moment to get used to is not catching the throttle pedal when hitting the brake while carefully backing up to hitch up a trailer. The higher throttle was. It was not an advantage in that one situation. Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 18, 2022 Share Posted May 18, 2022 There's different throttle pedals that are bent differently... or they bend over time. Not sure which it is. I put one that was much higher in my XJ because it hit the floor otherwise at full throttle (floor isn't stock shape because doubler). Link to comment Share on other sites More sharing options...
cruiser54 Posted May 18, 2022 Share Posted May 18, 2022 Check under the hood and see if there's slack somewhere. Perhaps that odd shaped piece of linkage with the plastic ends? Link to comment Share on other sites More sharing options...
yungupgrade Posted May 18, 2022 Author Share Posted May 18, 2022 2 hours ago, cruiser54 said: Check under the hood and see if there's slack somewhere. Perhaps that odd shaped piece of linkage with the plastic ends? I checked under the hood and I think I found the cable. When pulling on the wire on the left, it didn't feel like there was slack in the line. The connection to the bracket felt a little wobbly thought. Might just have to ziptie the pedal up higher in the cab. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 19, 2022 Share Posted May 19, 2022 IIRC, the one on the left is cruise control. Link to comment Share on other sites More sharing options...
yungupgrade Posted May 20, 2022 Author Share Posted May 20, 2022 On 5/19/2022 at 12:42 AM, cruiser54 said: IIRC, the one on the left is cruise control. My truck never came with cruise control from the factory though Link to comment Share on other sites More sharing options...
cruiser54 Posted May 20, 2022 Share Posted May 20, 2022 My mistake. Link to comment Share on other sites More sharing options...
