Neighbor has an 88 commanche he s asking 500 for, wanted to ask couple questions before I purchase. The transfer case shift lever is stuck in 4l, what could cause the? Expensive? Easy or hard to fix? Thanks.
The tcase shifter being stuck in 4lo could be as simple as needing to drive it around a bit while pushing it to get it to come out, or it could need some adjustment or new bushings, or the tcase could be screwed internally.
$200 or so for a used tcase and a few hours to swap it should be worst case scenario.
I'd have already bought it.
From what I can tell there isn’t a whole lot of rust but it up against some trees, kinda hard to look real good. So, not too expensive a repair?
considering the price of MJs these days, 500 is a great number, even if it needs work.  :L:
