oil in the breather box?
I removed the breather box this evening to have a go at the intake manifold bolts (didn't even get close), which led me to interesting discovery.
Oil is getting into the breather box somehow.
I couldn't tell for sure if it's all coming in through the, uh, fat line or the skinny lines that plug into the back of the box.
Maybe both.
On the inside of the box that spongey material that covers the skinny line inlets is pretty gooped up with oil, but there's evidence of it coming in through the fat line inlet just below as well.
Or maybe it's coming in through one and out the other.
It's certainly made a mess in the bottom of the box, keeping that bolt nice and lubricated I guess.
Looks like a previous owner parked near a mesquite tree.
And the filter is pretty well soaked.
Holding it up to the sun...
Rich deposits of oil infused dirt and gunk on the bottom where it's soaked through.
I cleaned the box up best I could before reassembly and banged the filter against the side of the trash can to get the solid gunk off of there but a new one is in order.
I had noticed faint traces of oil at the beginning of the air inlet connected to the box, but the throttle body itself didn't appear to be coated.  I worry that some of this is evaporating when the box gets hot, and going into the intake though.
It looks like a new filter is in order so first question, what's the best air intake filter to get?
The one that's in it seems rather high quality in nature.  Good material, looks like it's even covered with a metal mesh, but the media seems pretty well choked up with oil.
It might be a clean and reuse job, I've heard they exist but I've never messed with them.
Second question, what is this all this oil in the breather box a sign of?
PCV issue?
If not that I bet it involves some other acronym I'll have to look up.
Or is this just another creative way the old 4.0 uses oil?
CRUISER’S VALVE COVER MOD
Most early and even later Renix 4.0s could be bothered by excessive oil in the air cleaner box.
A fix from my old days as Service Manager at a Jeep dealership follows. Information was provided to me from a buddy at JeepTech during those days. I don’t believe it ever came out in a Technical Service Bulletin.
Remove the valve cover and turn it over. Next, remove the fluted tubes that are now facing you by removing three screws on each.
Valve cover flute
Chop 1 inch off each of them. Then, drill a half inch hole as shown in the photo. The flat side of the flute that’s closest to the edge of the valve cover. valve cover flutes (2)
Clean and de-burr/sand all rough edges nicely, clean with solvent, and reinstall. Don’t be concerned about the chintzy gaskets that will probably crumble into oblivion when you remove the fluted tubes. They can go back together without gaskets.
Here’s a handy video from my friend Brendan showing more detail.
I went through this. Its a common problem. Do the Cruiser tip. Also, get one of the FelPro silicon-rubber gaskets. I had issues with the cork ones. I found that the valve cover seal can also cause this issue. I also installed a '95 valve cover at that time. I like the 93-98 valve cover off the ZJ's though.
Thanks.
And thanks cruiser for the tip.
A new valve cover gasket is definitely on my list, and I might as well shorten the flute tubes while I'm at it.
Maybe both.
PCV issue?
Mesquite tree, huh? Sounds like where I grew up.
If you grew up around mesquite trees I was going to ask "Arizona or Texas?", but the answer looks like it's right there in your name.  :)
Just some info on how the crankcase vent system is supposed to function for anyone else using the search function.
There are two lines coming off the valve cover. The one on the back goes to the intake manifold, the front goes to the air intake box. In theory, the higher vacuum inside the manifold will suck gasses out of the crankcase, replacing them with clean air from the air box.
If the flow is interrupted by damaged or blocked lines, low manifold vacuum, leaking oil fill cap gasket or ccv fittings, or excessive blow by, the crankcase pressure will vent via the path of least resistance, generally pushing crankcase gasses and sometimes oil vapours through to the air box.
In this case it looks to me like it’s a reusable filter that was oiled excessively, which isn’t difficult to do. K&N makes a filter service kit with a cleaner and new oil that you can get at most parts stores, although if you want to go back to a standard filter just to confirm the oiling issue is taken care of, that’s not a bad idea either.
Thanks for the detailed info gogmorgo.
I love knowing how subsystems work. There are some useful videos out there showing where all the lines around a 4.0 start and end, but they don't give any context, and I like to know what things do.
I've though of taking images of the engine and trying to build maps of the various lines' endpoints with some sort of attached legend explaining their function. Then another image highlighting the various sensors, another for other bits, etc.  I bet somebody's already made them.
Anyway, from your description it sounds like if the manifold line were blocked, it would push air into the breather, so I definitely need to pull the manifold line and check for blockage.
If that's clear, I need to get on that compression check I've been thinking about, maybe the oil's getting pushed into the box by leaky valves.
I've heard a paper filter is a little bit better at catching dust than the reusable ones, and living in Arizona we got looooots of dust.
If I can get this figured out I'll probably switch.
Thanks again!
More likely the line would be damaged/leaking, but it's very possible it could've been plugged. Leaky valves don't generally leak combustion gasses to the crankcase, because you're not really building much pressure in either the intake or exhaust. Blow-by is what's blowing past the piston rings, high-pressure combustion gasses going straight to the crankcase.
That's not necessarily wrong, but I don't know that it's as big a deal as people make it out to be. High-performance does mean more flow, meaning more air going through, which does often mean larger particles can get through. I also imagine longer service life will eventually wear out the filter media in a reusable filter. One advantage to a reusable filter no one talks about is that the wire mesh on it means rodents can't chew through the filter. We park a bunch of our work fleet over the winter, and we've had more than a few filters turned into nests. A reusable filter is going to pass less dust than a paper filter with a big old hole in it.
Blow-By is as Gogmorgo explains. Yet, falsely, it is applied to your situation.  As described earlier, it is an imbalance in the CCV system that is likely causing this issue. The rear CCV is not pulling the amount of air needed. So, the suction from the intake ie filter side, is drawing in more air. With that, it is sucking in the oil from the valve cover. You could use an aftermarket breather on the front of the valve cover.  Or do the Cruise mod, Felpro silicon rubber VC gasket, upgrade the Valve Cover to a 91-95 HC VC or better yet, a 93-98 Grand Cherokee ZJ valve cover. Modify the rear line. Use 97-01 XJ rear line and fitting. I am taking it that yours is a RENIX. IF HO, then you could just do the rear line and fitting.
       Also, I think Fram has better filtering on air filters. This does come at a cost. The flow through the filter is less. So, affect MPG  and power to an extent.
Have poked at a few more things around this mystery...
I did a compression check and the numbers look pretty good (130's), so I don't feel like there's any upward pressure from the cylinders.
I pulled the rear line off and blew through it and verified it's clear. I also pulled the back end of the rear line from the valve cover with the engine running, and I could actually hear it pulling air.  It stuck to the end of my finger pretty good too.
Then I pulled the front line from where it connects to the breather box and it had a verrry slight suction to it.  I'm not sure how much it's supposed to have but the loop seemed to be working, if a bit weak.  And I guess the pressures could shift and change as I drive.
My "pull the back line" test told me the intake was sucking on that line, but it did not tell me anything about the state of the elbow fitting that plugs into the top of the valve cover. I've heard those CCV fittings can get blocked or produce low flow situations, which might be a problem.  I'm not sure if that's a removable piece or not without pulling the cover though.
At this point, after verifying that slight suction at the breather itself, I'm a little stumped as to what's pushing oil out.
I do need to replace the valve cover gasket, at which point I plan to do the shortened pickup mod, and might replace the CCV fittings at that point, or just research and do one of the upgrades listed by 75sv1.
Rats shouldn't get a chance to next in this breather box, because HOPEFULLY I can get enough issues sorted that it'll get driven year round.  At the rate I'm going though, it might become a wildlife sanctuary before I get it very far.
You won’t have as much suction at the front line because the combustion gasses make up some of it. Seems to me the system is working pretty well, provided you’ve got good seals at the valve cover. Def do as Cruiser suggests tho still.
