1J7FT26L2KL414233
fiatslug87
Build Date: 8/20/88
Body: tl61
Selling Dealer: Von Byerly Jeep - Eagle
Salisbury, NC
*F2 DESCRIPTION NOT AVAILABLE -SA Charcoal BAYP 105 Amp Alternator
BCYP 95 Amp Battery CBAP Straight Back Bench Seat DGB All 4-Speed Automatic Transmissions
DHTP   EAAC All Engines EAFC
ERB 4.0L I6 MPI Engine GRVP Left Manual Mirror HAA Air Conditioning
MBJ Black Bumper MDA Front License Plate Bracket PE4 Colorado Red
RAAC All Radio Equipped Vehicles RCAP Audio SBAA Power Steering
TAAC All Tires TBB Full Size Spare Tire TNCA P195/65R15 Tires
YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z59P Left Front Spring Group Ix
Z78P Right Front Spring Group VIII 5ALA
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE
BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles
DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio
DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror
GUAS Open JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes
JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS
KDAS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only
LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps
MB1S Black Front Bumper MFFS Black Grille MHBS Fender Flares
MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares
NAAS Federal Emissions NBAS   NBKS EVAP Control System
NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QE4S Colorado Red
RACS Open SCBS Perforated Steering Whl SFAS Standard Duty Front Shock Absorbers
SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels
WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze
YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail
167S Zone 67-Charlotte
Hi Jason,
Thank you for posting the build sheet.
As a new guy, I am wondering how to understand the info on the sheet.  Are all of the items on the sheet included on the Comanche with that VIN?
Dan
yes and no.  the codes above are all yours, though the meanings may have changed over the years because chrysler reused codes.  I've gone through and edited out the most common ones (for example, you don't have a "Mopar hood lock", the code JKBS likely applies to an internal hood release handle and chrysler reused it for later wranglers).  the other issue is that there was apparently a flood in the records room (at least that's the story we hear) and not all of the codes got entered into chrysler's computers. :(  if you look around at the various years, older years have way less codes pop up than newer years, when in reality they should have similar lengths of printout.
errors may still remain (like the hood lock since I missed that).
Thanks.
Got it.  Items like the engine, transmission, rear axle type and ratio, color, A/C, and Power steering would apply.
The Comanche is to be a 2 wheel drive,  I will be inspecting it this evening, but there is a code DHTP on the sheet meanin Shift-on-the -fly, P/Time, T/case that I assume does not apply if a 2WD.
Dan
that's something to look into for sure. :L:  that code could be a reused that used to mean 2wd but now applies to something else.  technically it used to say "Electric shift on the fly" and I edited the electric out. please report back with what you find. :D  I may need to re-edit a bunch of entries.  lol
