eaglescout526 Posted April 24, 2022 Share Posted April 24, 2022 Currently in search for 84-86 XJs with the selec-trac 4wheel drive set up. The mode shifter and other things associated with the set up. I need the following: Mode shifter assembly, this shifts the t-case from 2wd-4wd on the fly Below is the part above broken up oh and No.20 for the shifter itself. Annnnnd: No 21 in this pic. I will try my 207 lever when it is out if nothing pops up. Parts can also be found on SJ's as well. Link to comment Share on other sites More sharing options...
89 MJ Posted April 24, 2022 Share Posted April 24, 2022 Hmmm, I wonder if anything is interchangeable with my Eagle t-case. From my understanding, the NP128/129 was nearly identical, it just didn’t have low range. I won’t have it out for a while, but let me know if there is anything you’d want from it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 24, 2022 Author Share Posted April 24, 2022 2 hours ago, 89 MJ said: Hmmm, I wonder if anything is interchangeable with my Eagle t-case. From my understanding, the NP128/129 was nearly identical, it just didn’t have low range. I won’t have it out for a while, but let me know if there is anything you’d want from it. Will do! Someone has me covered for most, if not all the parts I need for this swap. But I’ll keep ya in mind if I come to find I’m missing something. Thank ya! Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 8, 2023 Author Share Posted October 8, 2023 Bump. I need the vac shift motor/actuator and the shift plate bolted to the t-case that changes the mode. I’ll find some diagrams and update the first post with them. 228/9 was found under SJs and XJs. Link to comment Share on other sites More sharing options...
Pete M Posted October 8, 2023 Share Posted October 8, 2023 this thingie? https://www.ebay.com/itm/256233452239 Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 8, 2023 Author Share Posted October 8, 2023 57 minutes ago, Pete M said: this thingie? https://www.ebay.com/itm/256233452239 Yes haha. I am currently watching that one. I figured I would reach out here first and see if anyone can locate an older XJ. I need the plate that the rod at the end of the actuator bolts into as well, my 229 is missing that plate but I have to take it apart as I can not get it to change from 4wd back to 2wd. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 8, 2023 Author Share Posted October 8, 2023 Post updated with pics. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted November 7, 2023 Share Posted November 7, 2023 I can verify that the Eagle's vacuum shift mechanism is the same as the jeep one. When I swapped a 229 into my eagle everything bolted right up and works great. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 7, 2023 Author Share Posted November 7, 2023 29 minutes ago, Eagle_SX4 said: I can verify that the Eagle's vacuum shift mechanism is the same as the jeep one. When I swapped a 229 into my eagle everything bolted right up and works great. So I can use an Eagle set up too? Great to know actually. Link to comment Share on other sites More sharing options...
