Whitaker717 Posted April 23, 2022 Share Posted April 23, 2022 Hi guys, I picked up some metal pieces with the studs, sorry I don’t know what they are called , to attach the plastic retainer to the outside flair. The problem is I am not sure how they go in. I’m guessing RR is passenger side? Some are labeled and some are not. Some say RR RH, some say center cargo box which I am guessing is the rear. Does anyone have a diagram on how they go? I’m guessing the metal pieces go into the outside of the flair, then the plastic inside piece goes over the studs. I’m not sure though so any help would be appreciated I am a bit lost Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 23, 2022 Share Posted April 23, 2022 I’m about to pull mine off so I’ll let you know later today or tomorrow. Link to comment Share on other sites More sharing options...
Pete M Posted April 23, 2022 Share Posted April 23, 2022 the good news is they only work one way so you should be able to do trial and error style with the flares. Link to comment Share on other sites More sharing options...
Whitaker717 Posted April 23, 2022 Author Share Posted April 23, 2022 Will this work if I de use to replace them all? Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 23, 2022 Share Posted April 23, 2022 The fronts will work but the rears are MJ specific. Yes, the metal retainers through the flare, the retainers through the fender and the then the liner. Here are the PNs and descriptions stamped on the retainers and their placement (back side of flare). Let me know if you can't read them and I can email the pics to you (CC shrinks their resolution). Link to comment Share on other sites More sharing options...
Whitaker717 Posted April 23, 2022 Author Share Posted April 23, 2022 That’s awesome man. I'm not super smart but which one is which? Rear, front, driver side passenger side. If I decide to replace them all do you know if this will work on our trucks. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 23, 2022 Share Posted April 23, 2022 SEE edited pics above Again, the fronts will work but the rears are MJ specific. Link to comment Share on other sites More sharing options...
Whitaker717 Posted April 23, 2022 Author Share Posted April 23, 2022 Any idea where I can get the 2 fat pieces for the drivers side? I also need the front inner plastic piece that bolts to the flare. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 24, 2022 Share Posted April 24, 2022 The driver side front or rear retainers? If rear, only from an MJ at a JY or someone on here or farcebook or eBay parting one out. The front liners can still be purchased new OEM, they are PNs 55001890 and 55001891. @eaglescout526 can probably help you out. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 24, 2022 Share Posted April 24, 2022 Indeed I can with the front liners. Link to comment Share on other sites More sharing options...
