1988-1998 Comanche build!
  • Replies 93
Got the dash lined up heater box mounted and steering column mounted. Now comes wiring and finish mounting dash. Welded the donor dash mounts in.
Also started cleaning up the manual doors for the manche.
Both doors and both fenders are on. Gotta readjust the doors a little bit to fix a couple body lines. But other than that now it’s onto brake lines fuel line and finding a ax15 cross member and bracket. :/
Bought new carpet but decided to try to fit 97 front carpet in the cab instead. Had to trim the back some and one the sides and then make cuts for the seat bolts. Actually worked out pretty good. Should clean up pretty good.
not pictured but I threw my bench seat in to see how it looked and felt still undecided. But this is how a 97 center console looks lol
Got a little bit done today. Took the bench seat off the brackets drilled them farther back so now it’s perfect I’m 6’3”. Plan to go bucket seats eventually this bench seat is shot. Got that back in just gotta bolt the seat belts back down. Also got the ax15 bolted to the motor. Put a new pilot bearing and throw out bearing on as well. got the motor in and bolted down. Still gotta source a cross member and bracket. Unless I go long arms…
Cut down a xj headliner and put new fabric on and got that in the Comanche. Here’s the dimensions if anyone is wondering. 0EFD72E2-2E9B-40B4-965B-F651FB05242F.jpeg.0d2d108686d35ec965f5b55593657974.jpeg
here’s with the new fabric.
also cut down a scrap center console I had still undecided. Definitely gonna paint it black or grey.
that’s it for now. Haven’t had a lot of time lately.
8 hours ago, Pete M said:
good to know we can still order an exhaust.  :D   love the console. :L:
Yeah you can get manifold all the way to the rear exit still it all either welds or clamps together. I was surprised too
