watchamakalit Posted February 9, 2022 Share Posted February 9, 2022 In the last week or so I have developed a high idle after the truck is warm. Everything is ok when cold. Once it starts to get even a little heat in the motor the idle settles in between about 1250 and 1500 and won't come down for nothing. Need suggestions. I'm pretty sure its a sensor issue somewhere. Link to comment Share on other sites More sharing options...
Pete M Posted February 10, 2022 Share Posted February 10, 2022 Could be heat expansion pulling the intake manifold from the head. Double check the torque on the bolts. Link to comment Share on other sites More sharing options...
MiNi Beast Posted February 10, 2022 Share Posted February 10, 2022 Tps Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 Didnt think about heat cycling. Ive had intake bolt issues with this truck before so its very plausible. Tps seems like it would be a constant problem even when cold. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 10, 2022 Share Posted February 10, 2022 I wouldn't rule out the TPS. Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 Well I can rule out the intake bolts. Just checked them and all tight. I guess its on to testing the tps..... Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 tps test values: 4.9V between terminals A/B .7V between B/C with throttle closed. Looks like it could use some adjustment but seems to be reading good when I sweep the throttle open it seems to be a nice smooth climb in voltage. Doesn't seem to jump around or blank out. Are the values far enough off I need to adjust it? Might be my cheap @$$ dvom also.... Link to comment Share on other sites More sharing options...
cruiser54 Posted February 10, 2022 Share Posted February 10, 2022 Can't hurt. Tip 5 and 6 done? Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 1 hour ago, cruiser54 said: Can't hurt. Tip 5 and 6 done? Yup. Did all that before I swapped this harness in. Am pretty sure ive fully cruserfied this truck except for a dizzy indexing. Link to comment Share on other sites More sharing options...
Pete M Posted February 10, 2022 Share Posted February 10, 2022 have you tried spraying a bit of carb cleaner around the intake manifold gasket? even if the bolts are tight, it might still be leaking. Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 I have not. I had kinda ruled out vacuum leaks with it idling good cold. Ill check it out.... Link to comment Share on other sites More sharing options...
MiNi Beast Posted February 10, 2022 Share Posted February 10, 2022 Next be o2 sensor but i just throw parts at it without testing things first. Link to comment Share on other sites More sharing options...
watchamakalit Posted February 10, 2022 Author Share Posted February 10, 2022 I'm gonna try not to go that route for a change. Link to comment Share on other sites More sharing options...
watchamakalit Posted March 1, 2022 Author Share Posted March 1, 2022 Update: high idle has become constant, regardless of temp. I found this issue today. Time to clean a TB...... Link to comment Share on other sites More sharing options...
watchamakalit Posted March 1, 2022 Author Share Posted March 1, 2022 Upon close inspection you will notice I am wrong in my first diagnosis of a dirty TB. Look close at the cruise control cable and its orientation in the bracket. The servo cable is holding the throttle open. Unhooked it and ill is back to normal. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 1, 2022 Share Posted March 1, 2022 Good deal. Sometimes its just a matter of looking at things closer and understanding how things are suppose to work. Good job figuring it out. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 1, 2022 Share Posted March 1, 2022 Excellent!! Link to comment Share on other sites More sharing options...
