75sv1 Posted October 17, 2022 Share Posted October 17, 2022 I did install the Heater Treater Blend door, yesterday. I think Doorman makes a plastic replacement kit too. Everything went OK. The Heater Treater uses flats on the shaft to match the ones on the blend door motor. The replacement blend door motor(s) came with splined parts. The original Blend Door had this insert. So, a negative with the Heater Treater, is the blend door might not full move to seal the one side. The side towards the firewall. I have actuated it, with the cut out not in place. So, about 1/8 to a 1/4 gap. I haven't road tested it yet. Link to comment Share on other sites More sharing options...
75sv1 Posted October 18, 2022 Share Posted October 18, 2022 Road tested this morning. Low temps outside, and some reported snow flakes. Heat worked. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted October 19, 2022 Share Posted October 19, 2022 On 10/18/2022 at 7:30 AM, 75sv1 said: Road tested this morning. Low temps outside, and some reported snow flakes. Heat worked. Excellent work! I'm hoping to get my new heater core installed before I see this years first flakes. Fingers crossed. Link to comment Share on other sites More sharing options...
75sv1 Posted October 20, 2022 Share Posted October 20, 2022 I did gas up the other day. I notice liquid under neath. Yeah, just what I need. I went back home and drove the Volt in to work. Fortunately, it was just the upper radiator hose. At least it happened at home and not on a road trip. Link to comment Share on other sites More sharing options...
A-man930 Posted June 26, 2024 Author Share Posted June 26, 2024 Sorry for the late revival, but I wanted to share what condenser I finally ended up with. No performance to report yet, but this is a modern style design to go with the late evaporator. https://www.amazon.com/gp/product/B00TI1ZHI2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
NickyV Posted March 4 Share Posted March 4 Bringing this thread back to life if I can! I've had my HVAC box for like three years, and I'm finally starting the process of pulling it apart. Trying to take good video to make a legit how-to. But I have a question for anyone who cares to answer. More than one honestly, but I'll take them one at a time. A lot of the super thin foam -- the stuff that's on the interior walls of the box -- seems to actually be in OK shape. I mean, it's not brand new, but it isn't crumbling. If I do end up replacing that. What foam should I get? Is there a specific kind? Or will any porous squishy foam work? I have a bunch of sound insulation foam that I've been cutting to size. The kind you would use for a recording studio. But it occurs to me that maybe there is a specific kind of foam I should be using. @A-man930 Link to comment Share on other sites More sharing options...
A-man930 Posted March 10 Author Share Posted March 10 On 3/3/2026 at 10:27 PM, NickyV said: Bringing this thread back to life if I can! I've had my HVAC box for like three years, and I'm finally starting the process of pulling it apart. Trying to take good video to make a legit how-to. But I have a question for anyone who cares to answer. More than one honestly, but I'll take them one at a time. A lot of the super thin foam -- the stuff that's on the interior walls of the box -- seems to actually be in OK shape. I mean, it's not brand new, but it isn't crumbling. If I do end up replacing that. What foam should I get? Is there a specific kind? Or will any porous squishy foam work? I have a bunch of sound insulation foam that I've been cutting to size. The kind you would use for a recording studio. But it occurs to me that maybe there is a specific kind of foam I should be using. @A-man930 I don't know if it's correct, but i went with a closed-cell foam for the inside of the box. No, I haven't had an opportunity to see how it holds up Link to comment Share on other sites More sharing options...
Warthog Posted March 10 Share Posted March 10 10 hours ago, A-man930 said: I don't know if it's correct, but i went with a closed-cell foam for the inside of the box. No, I haven't had an opportunity to see how it holds up There is a guy on Cherokee forum that was selling whole foam kits for refurbishing. Awesome products! Gotta order another one! Got a mj and xj build going. Link to comment Share on other sites More sharing options...
