Geek Posted January 5, 2022 Posted January 5, 2022 Hello, I am working on my Comanche project and looking for gears. I have the original Dana 30 front and a Dana 44 rear from an XJ. Does anyone know if the master install kits from a TJ will work? It says for 26 splines but the information I find, i believe the dana 30 is 27 spline and the dana 44 is 30 spline. I am looking to do 4.56 gears in it. I found this one from Yukon on Quadratec Yukon Gear & Axle Front & Rear Ring and Pinion with Master Install kits for Jeep Wrangler TJ with Dana 30 Front / Dana 44 Rear | Quadratec
87Warrior Posted January 5, 2022 Posted January 5, 2022 I used the TJ Yukon D44 master install kit for my MJ D44. It went together without a problem. You will want to make sure the D30 install kit is for a High Pinion (reverse rotation) D30. TJ's did not come with a HP D30, but XJ's did up to 1999. https://www.yukongear.com/shop/yg-d30r-456r
ktmall07 Posted January 6, 2022 Posted January 6, 2022 @87Warrior does that mean a 92 MJ D30 is high pinion as well, or is that exclusive to XJ's?
87Warrior Posted January 6, 2022 Posted January 6, 2022 2 hours ago, Pete M said: all MJ dana 30s are high pinion. Yup! That is unless somebody swapped in a low pinion 30.
ghetdjc320 Posted January 7, 2022 Posted January 7, 2022 Looks like your trying to get a kit that represents what you have. I’d recommend you jump on rock auto and grab a master install kit for your MJ D30 front and D44 rear. Revolution axle and gear is my personal favorite. You won’t get the appropriate oil slinger with that TJ kit.
