oleskool Posted December 29, 2021 Posted December 29, 2021 Like the title says. What is this vac line for? I am assuming it’s a vac line. I circled it and where it goes on the engine. It runs into the firewall. TIA
jdog Posted December 29, 2021 Posted December 29, 2021 The heater switch,if possible you can call the end on the firewall and delete the heater hose piece
tugboat95 Posted December 29, 2021 Posted December 29, 2021 The heater switch,if possible you can call the end on the firewall and delete the heater hose pieceYep, I capped mine off when I did the open cooling conversion. And just cut all that out.1989 Eliminator4.0L 5 speed2wd
cruiser54 Posted December 30, 2021 Posted December 30, 2021 Heater control valve. Eliminate it and cap off the line.
