Spring over.
88 Comanche long bed 4.0 4x4 automatic. I’m getting close to do my spring over. That way I can get rid off all the add a leaf’s and longer shackles. My question is will my driveshaft be long enough to use until I do my slip yoke kit with a double Cardin ujoints at a later date.
If don't flex out the rear till then it should stay engaged, however may utilize a 1" tcase drop or longer slip yoke to easily add an 1" or so to shaft. You don't really need to do a sye if don't want to. I run 8.5" lift with spring over and still use a factory slip yoke design. Was only $100 to have drive shop retube my driveshaft. :dunno: I different option anyways.
