Jlindsey86 Posted November 8, 2021 Posted November 8, 2021 I am planning on replacing my front coil springs as they are original and I assume a bit tired. I am not looking to increase the factory right height of the truck. Autozone sells Duralast Coil Spring FCS778V. Does any one run these and know if they are a direct OE replacement? Open to other brands as well.
Pete M Posted November 8, 2021 Posted November 8, 2021 I would measure first to see what height you're at currently. the factory method is in the link in my signature.
Jlindsey86 Posted November 8, 2021 Author Posted November 8, 2021 20 hours ago, Pete M said: I would measure first to see what height you're at currently. the factory method is in the link in my signature. I measured today from the top of the axle tube to the frame rail. Not sure if I measured in the correct spot but measured showing a distance of about 6.5"
Pete M Posted November 8, 2021 Posted November 8, 2021 is your truck 2wd or 4wd? you should add some details into your signature
Jlindsey86 Posted November 9, 2021 Author Posted November 9, 2021 2 hours ago, Pete M said: is your truck 2wd or 4wd? you should add some details into your signature 1992, 4.0, AX-15, shortbed, 2WD with the D35. Not finding where I can edit my signature on my phone. Will have to look on the pc.
Pete M Posted November 9, 2021 Posted November 9, 2021 factory for a 2wd is 6.75" +- 0.5" so it looks like you are spot on. I normally use a laptop and so I grabbed the phone and looked around on the mobile version and couldn't find anything about the signature. weird. maybe someone else knows the trick.
dasbulliwagen Posted November 9, 2021 Posted November 9, 2021 If you think your front looks a little low, you could add one inch spacers to your current springs. Also good new gas charged shocks would help out a little if you don't know when or if they have ever been done.
Strokermjcomanche Posted November 9, 2021 Posted November 9, 2021 Iirc zj springs will give you an inch more lift than the XJ springs
Pete M Posted November 10, 2021 Posted November 10, 2021 21 hours ago, Jlindsey86 said: 1992, 4.0, AX-15, shortbed, 2WD with the D35. Not finding where I can edit my signature on my phone. Will have to look on the pc.
