CornFed Posted October 31, 2021 Share Posted October 31, 2021 Alright so the interior lights in my truck don't work. I have checked the fuse and saw on here to replace the headlight switch as that maybe the issue so I ordered one today it'll be in on Tuesday. The question I have is does anyone know where I can buy the actual light assembly? I'd prefer new if possible. I've got one on the driver side I'd like to replace but I don't have one at all on the passenger side. Coincidentally I could also use the Tan plastic that goes on the seat belt buckle if you know where to get that. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 31, 2021 Share Posted October 31, 2021 You can't get those new. Used or the Euramtec ones we all have been buying. Theyre such fragile pieces of French made crap. As for the seat belt cover, any GM vehicle from the same period should have them. Link to comment Share on other sites More sharing options...
acfortier Posted October 31, 2021 Share Posted October 31, 2021 Just to confirm, you did tilt the lights up or down when you were trying them right? Took me forever to remember/figure that out. Link to comment Share on other sites More sharing options...
Pete M Posted October 31, 2021 Share Posted October 31, 2021 is there any 12v power at the light? Link to comment Share on other sites More sharing options...
howeitsdone Posted October 31, 2021 Share Posted October 31, 2021 54 minutes ago, acfortier said: Just to confirm, you did tilt the lights up or down when you were trying them right? Took me forever to remember/figure that out. This, I didn't realize my lights worked until I removed the interior trim and realized it tilted... Link to comment Share on other sites More sharing options...
CornFed Posted October 31, 2021 Author Share Posted October 31, 2021 53 minutes ago, acfortier said: Just to confirm, you did tilt the lights up or down when you were trying them right? Took me forever to remember/figure that out. 25 minutes ago, Pete M said: is there any 12v power at the light? I personally tested the plug with a 12v circuit tester there is no power to the plug what so ever. I've replaced the fuse just to be on the safe side and still no power. I'm hoping the new headlight switch will fix it. Link to comment Share on other sites More sharing options...
CornFed Posted October 31, 2021 Author Share Posted October 31, 2021 1 hour ago, eaglescout526 said: You can't get those new. Used or the Euramtec ones we all have been buying. Theyre such fragile pieces of French made crap. As for the seat belt cover, any GM vehicle from the same period should have them. Where can I find the euramtec lights would I search for them for a comanche? Or if you have a picture so I can see what I'm looking for. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 31, 2021 Share Posted October 31, 2021 Just google “euramtec Comanche” and look for posts from this site. I’d do it myself if i had the time. Can’t remember what the euramtec part number is but it will pop up in one of those threads. Link to comment Share on other sites More sharing options...
CornFed Posted November 1, 2021 Author Share Posted November 1, 2021 Thanks I found them and ordered a set. Link to comment Share on other sites More sharing options...
