OldSch88L Posted September 29, 2021 Posted September 29, 2021 I got my new dash installed and was testing everything before the final reassembly. Pretty much everything works, exept B-pillar lights, footwell lights and the clock acted up. They barely worked intermitently, the lights being a dim orange. Now, none of them work, including the glove box light. The radio works but has no memory, and these results point to the dome fuse. All the fuses are OK, and I pulled out the dome fuse and put my multimeter leads on the fuse box terminals, and there's no power, while it should be hot at all times. I swapped the XJ dash with its as-new harness and fuse box following an how-to that I found here to match the wiring to the MJ. Could it be the black tar-like goo at the firewall fusebox connector causing trouble, or a fusible link somewhere? I tried everything I could, but electricity and wiring is not my cup of tea (translation: I freakin' hate it!) hahaha!
OldSch88L Posted September 29, 2021 Author Posted September 29, 2021 33 minutes ago, Minuit said: What year is the donor harness from? Well, it's a Renix era; the seller tought it was an '88 but wasn't sure, as he got it from a parts stash included with an XJ project... But I'm pretty sure I saw a 1990 date stamped on the cable-driven cluster that came in it.
cruiser54 Posted September 29, 2021 Posted September 29, 2021 Factory radio? If not, unplug it and see if your problem goes away.
OldSch88L Posted September 29, 2021 Author Posted September 29, 2021 2 hours ago, cruiser54 said: Factory radio? If not, unplug it and see if your problem goes away. Yes, AMC RX135 radio.
OldSch88L Posted October 4, 2021 Author Posted October 4, 2021 Well, I finally found the culprit; turns out XJ and MJ dash harnesses aren't always plug and play. The wire that feeds power to my particular XJ dash's dome fuse, red with white tracer, comes to a dead end on pin A6 on the XJ bulkhead connector, while it's actually on pin D4 on the MJ connector. Weird...
Pete M Posted October 4, 2021 Posted October 4, 2021 I just assume every single year and model and individual Renix Jeep is different than then next when it comes to wiring.
OldSch88L Posted October 4, 2021 Author Posted October 4, 2021 51 minutes ago, Pete M said: I just assume every single year and model and individual Renix Jeep is different than then next when it comes to wiring. I guess that's not far from the truth... Another curveball I had was that all the diagrams I could find said that constant 12V in the dash was the red/tan wire, while it's a pink wire in that XJ dash. The only thing left figuring out is the darn clock wiring because neither the wiring nor the connector match any info I could find...
Minuit Posted October 4, 2021 Posted October 4, 2021 51 minutes ago, OldSch88L said: I guess that's not far from the truth... Another curveball I had was that all the diagrams I could find said that constant 12V in the dash was the red/tan wire, while it's a pink wire in that XJ dash. The only thing left figuring out is the darn clock wiring because neither the wiring nor the connector match any info I could find... Post a picture of the clock plug. It and its pinout changed frequently.
OldSch88L Posted October 4, 2021 Author Posted October 4, 2021 11 hours ago, Minuit said: Post a picture of the clock plug. It and its pinout changed frequently.
OldSch88L Posted October 11, 2021 Author Posted October 11, 2021 Finally figured the clock on my own. For those interested, the wires coming out the clock are: Red Constant 12V Black Ground Blue Acc 12V Yellow Park Lamps (usually the orange/black tracer wire in the dash) Orange Panel Illumination ( was a blue wire in my dash, varying voltage controlled by the light switch's dimmer ) Hope this saves the next person some time!
Pete M Posted October 11, 2021 Posted October 11, 2021 I think there's a clock wiring diagram in the link in my signature. how does yours compare to it?
OldSch88L Posted October 12, 2021 Author Posted October 12, 2021 8 hours ago, Pete M said: I think there's a clock wiring diagram in the link in my signature. how does yours compare to it? Well, I went through your master index twice and couldn't find it. In fact, any info on that quartz clock with that particular blue connector is scarce even on the web. Most people seem to have the one with a black connector?
Pete M Posted October 12, 2021 Posted October 12, 2021 huh, I guess it didn't get included. lemme see if I can find it...
Pete M Posted October 12, 2021 Posted October 12, 2021 http://gojeep.willyshotrod.com/HowtoDashClock.htm
