Hey all. So I just recently put the engine in the Comanche and as I was putting brake fluid in last night I noticed it had a decent vaccum leak at the map sensor. After fixing it, it seems as if it runs just as rich as before. What would cause that? I know my EGR is bad but I can’t find any replacements or ways to block it off. Engine idles both cold and warm at ~1100rpm and will backfire occasionally when shifting gears.
Things I have checked, installed or verified:
New injectors
IAC
TPS and it’s adjustment
MAP sensor
vaccum leaks
coolant temp sensor
Things I haven’t checked
manifold temp sensor
any help is appreciated
I’ll say it before anyone else: perform Cruiser’s Renix tips first. Next, purchase Nickintimedesign’s Renix Engine Monitor (REM).
the idle is to high. It should be ~750rpm. Probably a vacuum leak. Check all hoses and tighten the manifold bolts.
Running rich maybe from prior vacuum leaks. The ECU may need to adjust the fuel trim.
The REM will help identify other issues with the engine components operation
