Parasitic Battery Draw
This one has me stumped! I am usually good at wiring probs And I've read most of all the stuff on here about this But.....
1987 MJ plain long bed 6cyl. The draw is 0.02 amp at the full volts of the battery. I unplugged the Alternator with no change.
I unplugged the ECM and it dropped to 0.01 amp. That is the best I could find. I know its not much but it is draining my battery.
Any ideas will be gratefully appreciated!
Rccubed
0.02A is not a lot. I don't know if there's a proper spec for an MJ, but as a general rule that's acceptable. A typical group 34 battery in good health should be able to put out that much current for well over a month before you have issues starting. Have you tested the battery?
I haven't load tested it, but I plan on that today.
On 9/23/2021 at 9:37 PM, 89 MJ said:
Gosh, I left my truck sit all winter in less than 32 degree weather with the battery hooked up (December-Late March) and it didn’t kill it.
Is your glovebox light turning off?
No I have removed all the light sources.
