jtdesigns Posted December 4, 2007 Share Posted December 4, 2007 even if you did put it on the back, how was you going to remove it? Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 4, 2007 Author Share Posted December 4, 2007 even if you did put it on the back, how was you going to remove it? the whole front half or just the motor? if it is just the motor i could use a hoist, if it is the front half, i'd probably chain it up and put it out with another vehicle. Link to comment Share on other sites More sharing options...
StevenH Posted December 4, 2007 Share Posted December 4, 2007 I must be lost, but are you getting the entire frontend of a truck just for a TBI harness? TBI is not that complicated, you can easily get the harness out. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 4, 2007 Author Share Posted December 4, 2007 i most likely wouldn't get the whole front half. i got no way to haul it to my place, and i wouldn't need the rest of the crap that came with it, i just the need the engine and harness. we are talking about the front half a firebird. Link to comment Share on other sites More sharing options...
StevenH Posted December 5, 2007 Share Posted December 5, 2007 Look around at some f-body sites, browse at www.v8s10.org also. TBI is simple as heck as long as you know a little bit about it. It's pretty much a stand-alone system, it's a lot simpler than the Renix FI on my MJ. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 5, 2007 Author Share Posted December 5, 2007 alright. well i really don't know anything about it, i am still learning about a lot of this stuff. i can do some engine work and electrical work, but there's still a lot i don't know. Link to comment Share on other sites More sharing options...
StevenH Posted December 5, 2007 Share Posted December 5, 2007 Check this out http://www.automedia.com/TBI/Fuel/Injec ... 001001fi/1 Link to comment Share on other sites More sharing options...
StevenH Posted December 5, 2007 Share Posted December 5, 2007 alright. well i really don't know anything about it, i am still learning about a lot of this stuff. i can do some engine work and electrical work, but there's still a lot i don't know.Sign up at v8s10.org and ask questions if you need to. I go by the name chevy350 there S10Wildside on that forum makes custom harnesses if you are interested, or ask in the wanted section and buy a used harness from someone Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 5, 2007 Author Share Posted December 5, 2007 damn, this will be real handy then. all this will work for the 3.4L swap into a manche right? i would assume it would otherwise i don't think you would have mentioned it, but i just want to make sure that it applies to that swap. Link to comment Share on other sites More sharing options...
StevenH Posted December 5, 2007 Share Posted December 5, 2007 I thought you were still doing the 4.3 but yeah, it will be same on the 3.4 as far as I know. Google it some more and you probably find some good explanations of how TBI works. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 5, 2007 Author Share Posted December 5, 2007 nah, i decided i would go with the 3.4L for now, until i have more time and money to fix 'er up better. alright, i will do that. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2007 Share Posted December 5, 2007 I thought you were still doing the 4.3 but yeah, it will be same on the 3.4 as far as I know. Google it some more and you probably find some good explanations of how TBI works. nope, not even close to correct. the 3.4 is a MPFI injection system, it has 6 injectors with a throttle body. not TBI. still easy, and like I said to him, he just needs the engine and IT'S harness....I wouldn't get an engine from one vehicle and a harness from another and even computer from another, as things could be wrong. but, idk, I've only basically done this swap with a bit more pep anyways ;) the only reason I'd want the whole car is that you get the added insurance of having everything you'd possibly need. plus, I smashed my camaro even more before I yanked the motor :roll: Link to comment Share on other sites More sharing options...
StevenH Posted December 5, 2007 Share Posted December 5, 2007 I didn't sleep at a Holiday Inn last night but I bet if you wanted to put TBI on a 3.4 you could do it ;) What exactly are you doing? edit: I scanned back over the whole thread and don't even know where I got that you were doing TBI from :D Didn't 2.8's have TBI at some point? You could probably use that if TBI is the way you are going. Also, the van that the 4.3 is/was in has a TBI harness at your disposal if you have it. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2007 Share Posted December 5, 2007 I didn't sleep at a Holiday Inn last night but I bet if you wanted to put TBI on a 3.4 you could do it ;) What exactly are you doing? edit: I scanned back over the whole thread and don't even know where I got that you were doing TBI from :D Didn't 2.8's have TBI at some point? You could probably use that if TBI is the way you are going. Also, the van that the 4.3 is/was in has a TBI harness at your disposal if you have it. 2.8's from a chevy s10 or blazer would have the TBI. retrofitting a TBI from something like a 4.3 to a 2.8 (or 3.4) would be expensive, making the swap pointless. also, putting that TBI or carb from the 2.8 on would kill power and economy...the point is to get both, and MPFI can give that to you alot better, plus I'm not even kidding, there's about 20 wires to remove entirely, and 7 to splice, and a fuse box in the engine bay to alter (remove ABS control, air shock control, etc). it's really not rocket science...you're tricking the motor into thinking it's still in the camaro Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 5, 2007 Author Share Posted December 5, 2007 I didn't sleep at a Holiday Inn last night but I bet if you wanted to put TBI on a 3.4 you could do it ;) What exactly are you doing? edit: I scanned back over the whole thread and don't even know where I got that you were doing TBI from :D Didn't 2.8's have TBI at some point? You could probably use that if TBI is the way you are going. Also, the van that the 4.3 is/was in has a TBI harness at your disposal if you have it. 2.8's from a chevy s10 or blazer would have the TBI. retrofitting a TBI from something like a 4.3 to a 2.8 (or 3.4) would be expensive, making the swap pointless. also, putting that TBI or carb from the 2.8 on would kill power and economy...the point is to get both, and MPFI can give that to you alot better, plus I'm not even kidding, there's about 20 wires to remove entirely, and 7 to splice, and a fuse box in the engine bay to alter (remove ABS control, air shock control, etc). it's really not rocket science...you're tricking the motor into thinking it's still in the camaro once i get the engine and harness and begin the swap i will let you know, in case i run into any problems. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 5, 2007 Share Posted December 5, 2007 lol, I'm no expert, but I've got the wiring diagrams and my swap was very similar...how I did it may not be your style, just would like to try to ensure that you run into as few of problems as possible. Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 5, 2007 Author Share Posted December 5, 2007 haha well i didn't figure you were, but i did figure you know what you are talking about. well i haven't developed a style for this type of thing yet so i don't really have one. Link to comment Share on other sites More sharing options...
StevenH Posted December 6, 2007 Share Posted December 6, 2007 I was browsing advanceadapters.com and they might have an adapter for a 4.3 to your transmission. If you have a torqueflite it will be able to hold up. The downside is the adapter will cost around $500 but if you already have the engine and everything to go with it, that actually isn't that expensive. Have you decided on what you are doing? What engine and fuel system? My opinion is don't run the 60* V6 if you want anything that resembles performance. I obviously don't know anything about the 3.4 but if it's like the 2.8 it's junk. A 3.4 is definately your easiest swap if that is what you are after. You would not have to get driveshafts made or fab anything up, it would be basically a bolt-on mod. Another suggestion is just get the engine in there and run a carb and come back and do FI as another project. Or you could swap the entire drivetrain instead of buying the 4.3 adapter. For $500 you could buy a used transmission and transfercase. You have a lot of options on this actually... Link to comment Share on other sites More sharing options...
Pete M Posted December 6, 2007 Share Posted December 6, 2007 Don't worry, the 3.4L is nothing like the old 2.8 when it comes to performance. If I remember right, it put out 160 hp in the Camaro. What was the 2.8L, 110hp? Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 6, 2007 Author Share Posted December 6, 2007 Don't worry, the 3.4L is nothing like the old 2.8 when it comes to performance. If I remember right, it put out 160 hp in the Camaro. What was the 2.8L, 110hp? i thought the camaro put out 140 and the firebird put out 160? maybe i read something wrong or mixed em up. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 6, 2007 Share Posted December 6, 2007 they're the same Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 9, 2007 Author Share Posted December 9, 2007 is it possible to convert or get a tbi 3.4L? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 9, 2007 Share Posted December 9, 2007 is it possible to convert or get a tbi 3.4L? get a camaro 3.4 longblock and get any 80's chevy s10 fuel injection intake, throttle body, air filter @$$'y, valve covers, engine bay wiring, and under-dash wiring. the computer is under the right hand side of the dash. sounds like that would be easier for you to do, but chasing down parts between different cars sucks. ...like for my 3800 swap, I have all engine components from a 3.8 camaro 1996, I have a renix 4.0 radiator, a HO 4.0 condensor and dryer, a ford v8 mpfi in-line fuel pump, and that was the easiest way for me to go... Link to comment Share on other sites More sharing options...
tkgibbs27 Posted December 9, 2007 Author Share Posted December 9, 2007 i better start making a list of everything i need. you were all over the place then. there's a guy at my work said he can most likely get me an engine for cheap because his brother. and if i can find out if my engine has large journals i can trade him and get it a whole lot cheaper that way. Link to comment Share on other sites More sharing options...
tireman Posted December 17, 2007 Share Posted December 17, 2007 when installing the 3.4 has anyone used the serpentine belt parts to eliminate all the clutter? just seems cleaner ... Link to comment Share on other sites More sharing options...
