tireman
tireman's Achievements
  1. installed a 4x4 comp cam yesterday in my 86 w/2.8 for more low end torque & wondered if anyone has ever installed roller rockers for more low end torque. read on a 60degree engine website that 1.6 roller rockers will increase low end torque but not horsepower ... any comanche experience?
  2. after last post i did some searching on carquest weblink & found 88 s10 4x4 / 2.8 / serpentine belt driven w/reverse fan clucth ... now just need to locate brackets for 88 s10... thanks for the input
  3. what year was the doner s-10? :wall:
  4. has anyone ever converted over to 3.4 & keep serpentine belt drive? the only problem i can find is what to run for cooling fan due to reverse drive water pump will not work w/ fan clutch. i want to swap to serpentine belt but fan leaves me puzzled :headpop:
  5. this next week i plan on installing a 4x4 cam in my 86mj 2.8. has anyone ever tried aluminum valve covers off a 85-88 pontiac fiero? just for looks ... no other reason
  6. when installing the 3.4 has anyone used the serpentine belt parts to eliminate all the clutter? just seems cleaner ...
  7. where did you get the cowl for the hood?manufacturer or part #?
