youngfred Posted September 11, 2021 Share Posted September 11, 2021 ... Would this be overkill on a 2WD ? youngfred Link to comment Share on other sites More sharing options...
Smokeyyank Posted September 11, 2021 Share Posted September 11, 2021 Yes and no, upgraded tie is really only a upgrade for wheeling. If you bash it on a rock don't want it to taco. If your 2wd is a track car then would be beneficial. If it's stock just get a ZJ tierod if you want some extra strength. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted September 13, 2021 Share Posted September 13, 2021 Agreed with above. Overkill is subjective. An HD tie rod doesn't "do" anything other than resist bending under impact or other shock load. Two things to consider. First, the added strength comes at the cost of added weight. A solid tie rod is probably 3x heavier than the hollow stock unit. Generally, I'd say don't add weight you don't need. Second, on the Synergy website it says that HD tie rod is designed to work only with the Synergy drag link. I don't know why. There are other HD tie rods on the market that mate up just fine with stock / ZJ drag links. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 13, 2021 Share Posted September 13, 2021 I believe the synergy tie rod connects lower in the drag link and therefore needs the matching drag link. The bigger consideration here is tire size and intended use as has been mentioned. Link to comment Share on other sites More sharing options...
75sv1 Posted September 13, 2021 Share Posted September 13, 2021 As ghetdjc points out, I think that is for a WJ setup. Some refer to it as cross over steering or OTK steering. I have 1-ton GM steering from Ruff Stuff on my two XJs. I like it. It seems more stable and less bump steer. On my 2" lifted XJ, I am not running a steering stabilizer on it. There are other set up for a beefed up 'Y' link. I do have an Iron Rock one, but not installed. I'll try and post a cross over steering setup. Link to comment Share on other sites More sharing options...
75sv1 Posted September 13, 2021 Share Posted September 13, 2021 As ghetdjc points out, I think that is for a WJ setup. Some refer to it as cross over steering or OTK steering. I have 1-ton GM steering from Ruff Stuff on my two XJs. I like it. It seems more stable and less bump steer. On my 2" lifted XJ, I am not running a steering stabilizer on it. There are other set up for a beefed up 'Y' link. I do have an Iron Rock one, but not installed. I'll try and pCategory: U-Turn - OffRoadOnlyost a cross over steering setup. Category: U-Turn - OffRoadOnly. I haven't used on, but I hear good things. Link to comment Share on other sites More sharing options...
Ynot777 Posted September 16, 2021 Share Posted September 16, 2021 If you off road there will always be a weak link or something to break. A bent stock tie-rod on mall crawlers can sometimes be the easiest and cheapest evil to fix steering component wise. They are easy to carry spare, find in stock at local stores, and junkyards about anywhere. You could have a spare fully loaded and premeasured ready to drop in for way less as well. Your build and goals with what you do with it should ultimately be the deciding factor. I personally have always left that intentionally weak on my mall crawlers for this very reason. Link to comment Share on other sites More sharing options...
