acfortier Posted September 8, 2021 Share Posted September 8, 2021 Will this work/fit on a Comanche? I'm seeing that they list this for a 96-98 ZJ, and then they have the Addco 516 for XJ/93-95 ZJ. I thought all years of a ZJ sway bar would fit a Comanche? Link to comment Share on other sites More sharing options...
Comanche SS Posted September 8, 2021 Share Posted September 8, 2021 They might have different part numbers for the limited zj or the V8 vs i6 models. It doesn't hurt to call and ask Sent from my Pixel 5 using Tapatalk Link to comment Share on other sites More sharing options...
acfortier Posted September 8, 2021 Author Share Posted September 8, 2021 It just looks like different part numbers for the different years. I checked on their website, 516 for the 93-95, 543 for the 96-98. They physically look different, too. Link to comment Share on other sites More sharing options...
MiNi Beast Posted September 8, 2021 Share Posted September 8, 2021 It would work, but the differences are in the diameter of the sway bar itself, utilizing different bushings as well. The thicker one being for the v8 zj and a common upgrade on mjs for a firmer more stable ride. 👌 Link to comment Share on other sites More sharing options...
acfortier Posted September 8, 2021 Author Share Posted September 8, 2021 35 minutes ago, MiNi Beast said: It would work, but the differences are in the diameter of the sway bar itself, utilizing different bushings as well. The thicker one being for the v8 zj and a common upgrade on mjs for a firmer more stable ride. 👌 Yeah, that makes sense. Just seems odd that they list them out separately, since the V8 was available starting in 1993, right?  Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 8, 2021 Share Posted September 8, 2021 If your looking for an upgrade to the stock bar you can get the 1.125” bar from a later XJ. I believe 94 was a crossover year. I picked up this bar since it’s was the larger oem version at an unbeatable price: https://teamcherokee.com/front-sway-bar-assembly-oem-jeep-cherokee-xj-1994-2001/  Also running the addco rear bar. Great combo with the 28mm oem front bar. I think it was Hornbrod who suggested this setup after trying several other versions.  Here is the thread discussing the addco and the later model oem:   Link to comment Share on other sites More sharing options...
acfortier Posted September 9, 2021 Author Share Posted September 9, 2021 3 hours ago, ghetdjc320 said: If your looking for an upgrade to the stock bar you can get the 1.125” bar from a later XJ. I believe 94 was a crossover year. I picked up this bar since it’s was the larger oem version at an unbeatable price: https://teamcherokee.com/front-sway-bar-assembly-oem-jeep-cherokee-xj-1994-2001/  Also running the addco rear bar. Great combo with the 28mm oem front bar. I think it was Hornbrod who suggested this setup after trying several other versions.  Here is the thread discussing the addco and the later model oem:   Woah, that's a great price! I found someone local selling the Addco 543 set for $80, figured that was worth the $$ rather than going the JY route, since I would need new bushings and all that. Was thinking about going to get a Blazer rear bar and do that, but it still seems like there may be a few of the Addco rear kits around. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 9, 2021 Share Posted September 9, 2021 1 hour ago, acfortier said: Woah, that's a great price! I found someone local selling the Addco 543 set for $80, figured that was worth the $$ rather than going the JY route, since I would need new bushings and all that. Was thinking about going to get a Blazer rear bar and do that, but it still seems like there may be a few of the Addco rear kits around. I ordered my rear addco bar a few months ago. They still make them new Link to comment Share on other sites More sharing options...
acfortier Posted September 9, 2021 Author Share Posted September 9, 2021 4 minutes ago, ghetdjc320 said: I ordered my rear addco bar a few months ago. They still make them new Addco 468 correct? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 9, 2021 Share Posted September 9, 2021 47 minutes ago, acfortier said: Addco 468 correct? Yep that’s right Link to comment Share on other sites More sharing options...
