Under dash wiring questions
The yellow box is the cruise control "brains".
The black box is the intermittent wiper control box.
The fuse is part of the cruise control wiring. Cruise wires S/B blue w/trace. Not sure what the pink wires are for.
Thank you, I appreciate the knowledge!
2 hours ago, eaglescout526 said:
They go to the brake switch. So if something happens to the brake switch and causes too much draw, it will blow the fuse to protect the regulator.
Great to know. Thank you.
Taped alongside the pink/pink w/blk is a white with black strip, this is the one that is plugged into the IGN terminal of the fuse block. I haven't traced it out yet, looks like it joins a harness going over the column. Everything still seems to function when it is unplugged.
Unrelated to my request for ID of under dash objects,
Any ideas why I have no door chime / headlight warning? I had assumed replacing my black module with the blue one would get me a door chime / headlight warning.
5 minutes ago, EUREKA said:
Any idea what this item is?
It’s all cruise control related. That’s the clutch switch so if you had a manual MJ there would be a plunger switch above the clutch pedal to momentarily cut power to the cruise control system. It’s a pretty neat system but tough to get working at times.
Ok, make sense. My CC does actually work.
How is your door switch?
3 minutes ago, jdog said:
The driver's side has two wires, one for the lights and the other for the headlight and key reminder
One of them must be floating around in the kick panel area, there was only 1 wire attached to the door switch when I replaced it. I wondered why the switch had a place for two terminals.
Thank you kindly, I now have a functioning door/headlight buzzer.
