1992 factory fog light relay
Hey guys. Looking for some help. In trying to set up my factory fog lights but I can't seem to get them to work. I have the OEM switch it lights up but no power to the actual fog lights. I know there is a relay but I can't seem to find it. It's a 1992. The Haynes manual was less then helpful. And Google does nothing. I found the fuse it's good. Now I'm trying to find the relay. Any Ideas?
  • 6 months later...
Might be late I did actually figure it out. I couldnt find it because it's not there. I go the wiring diagram and traced the wires. My headlight harness didnt have the fog light option. Truck side is all there. So all I have to do is ad in the relay kit and I'm good to go.
I ran into the same issue before and that is correct that if your Comanche did not come with the factory fog light option the relay is not there. Most of the wiring is there, I would recommend using some contact cleaner on the old existing plugs.
When I added mine, I wish I had kept better notes.  I ended up going to the junkyard and getting the harness pieces from a 91 XJ.  Even then, it seems like I had to re-pin my headlight harness connector to get it to work.  If you have access to the factory wiring diagram, just pay close attention as you wire it up and it should be fine.  And like JYau said, while you are in there, check that headlight harness connector near the airbox.  Mine was VERY corroded inside, to the point I ended up replacing some of the wires and terminals with ones from the junkyard XJ.
