JimB Posted July 21, 2021 Posted July 21, 2021 Hoping Eaglescout might be able to help. I am trying to find the antenna cable grommet. Willing to buy the entire cable if need be. Se attached pic. Need so i can put fender back on.
eaglescout526 Posted July 21, 2021 Posted July 21, 2021 Hahaha yeah let me look. I think they’re an entire wire so I don’t think they are separate.
eaglescout526 Posted July 21, 2021 Posted July 21, 2021 So they’re aren’t any left. I might have a cable or two but I think the connection to the antenna base is busted.
JimB Posted July 21, 2021 Author Posted July 21, 2021 I will make it work. What do you want for it? Restoring the 86. To deep into it right now to cut corners.
eaglescout526 Posted July 21, 2021 Posted July 21, 2021 I need to find them first but I won’t charge ya an arm and a leg.
ghetdjc320 Posted July 22, 2021 Posted July 22, 2021 Just as an option, I used a rubber floor plug and some urethane sealant. Works great. Put a small “drip loop” in the antenna cable before it enters the cab also.
Minuit Posted July 22, 2021 Posted July 22, 2021 Or if those options seem a little bit too sensible for you, convert to a power antenna like I did. The grommet is part of the assembly and is available new. You'll have to add the wiring all the way back to the fusebox, but hey.
