Posted (edited)
On my 88 Comanche, the driver's side Vent Window keeps fall off of its bottom pivot point. The passenger side is fine. Looks like there is a pin that is either broken off or bent. Curious if anyone has advice on how to fix this. I haven't taken the door apart yet but it's hard to tell exactly what this is and how to fix it. Thank you!!!
Qpi-AYzXC4oQs4S410rulaEhuqYXC4SI-pHSJmS1UHJ2Sgq4lxJ_jK9Rmr-itQ48u-j3ifjo8EWEh3art-cx0FA7c8Z0L009UbF7e18RXMuN9ue_BJsRcchhsVVXCA2-eFR7L839U3ANPP7Yl8Z4vrgxJTFs7NpOhgih0Wy0w4mWPnVIr1M_p3CI8P0cjGWPYQs4ms4KC1uG3zRemy606Nmzt0dVozAGx90ZTjLilvFp-gUIIy2Fd9GwgZvRFr91m2RaAatAmh7mzH6d3MEIlT50G0n6A3NliY1Bu4dOTi3X5hcMjAI6Zfib3DD9sVMStRfzlOTfVQOH-TzPWXrAYoTZF55PyOYvariAxGP5b8ZM5hNEb1SV9Wra5cDF7x-LGnhbYCK6kXgbx0tXSw2xRA91AfEwizJ-PdW-lyTy9YeJQlJcNIHB8y5P9-f8kYdAgEbpaVRBNoXzb9hRHjHOhGUfmNaulTUvlr-bbNqosC-kCM7nSQOEujIJmIZMO-7LSHe4JQozFXfbLN3Cd1Gutl2BE5_p9n1TueJI2cdHF_9LSdycenO1_gu7v8lx-FxjsaoHA8ZdVMLtGsNHHwsG6QHCyL1dGBD4xTZFvdOZU3uKDAJjhlgtuh7xEbfh2oSPne6A0fD5l-TNP4xx0vIVBUHWx-UqGdsBRBqBxWnjuBYcVjrlZlF9MYdBHbnLkBE3duOhPX1SHFjOOV2LsU6yh_ZC=w677-h902-no?authuser=0
Edited by VintageJC
Fix picture
Picture didn't work for me but if it is where I'm thinking it is and it's the bottom of the glass. It would probably be easier to replace it, they used that window from 84-96 and in cherokees
Jdog - Thx for your response. I posted a new picture above so maybe it works this time. I'll take out the entire triangle glass and check it out. As you said, may be easiest to try that first. However if you could see my picture, you'll notice the pivot point that is part of the door seems messed up.
Pete M - Thx for your response as well. Hopefully you can see the picture above. Yes the pivot is rusty and looks deformed.
The pin or pivot is broken and is not fixable.  You need to find another wing window or at least the frame the glass is in and replace it.
8 hours ago, VintageJC said:
Another stab at uploading pictures.
I see the photos in that last post. :L:
