HELP 89 Comanche 4.0 Constant Miss
Hello All
i have a puzzling issue with my newly acquired 89 Comanche 4.0
The truck has been sitting indoors for about 2 years prior to my obtaining it.
It ran great after draining a small amount of fuel out of the tank
I replaced a leaky valve cover gasket last night. (I was sober)
After putting it back together, I started it up and now it has a constant miss at all speeds.
Tonight I replaced Plugs, Wires, Cap & Rotor, Checked all vacuum lines, checked connections on Fuel injection.
Still have the miss.
Can anyone suggest anything else?
I have not replaced the fuel filter but have one and will replace it tomorrow.
I’m not new to Jeeps, but this is my first Renix. Thanks in advance
Two years is a very long time for gas to sit.  Given the symptoms I would guess it has fouled an injector or two.  I suggest draining the tank and putting fresh in along with a good injector cleaner and see if it clears up.  I wouldn't necessarily fill the tank this time, 10 gallons or so will allow for a more concentrated injector cleaner mix.  BG 44K is a very good one.
Update: 5 July 2021
Completed items 1-5 on the “Problem List” last night.
Drained entire fuel tank
Blew fuel lines out with low pressure
Changed fuel filter
Reconnected everything
Added 1/2 quart Lucas Fuel system cleaner and 1/2 tank of Premium.
Drove 50+ miles at highway speed
(Started and Stopped, etc)
Parked for several hours
Drove 20+ miles
Came home in time for dinner Lol
At first the truck ran like crap, shuttering, missing, cut off.
As I continued at Highway speeds the truck began to run better and better.
By the time I finished up around 6PM, it was idling without a miss, still had a hiccup every now and then.
My plan is to run the reminder of the fuel and additive out and wait until the “Good Stuff” arrives on Wednesday
Again, I can’t thank the forum for the great input! I’ll be in touch David
Also worth giving the vacuum lines a good check or just relaxing them altogether. NAPA has the front and rear vacuum harness’s for less than $50 total. You never know if the rubber in those o-rings has rotted or a line has a nice little pinhole
RENIX VACUUM HARNESSES
Vac harness 7151367
The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367 or is a Dorman 46003.
Vac harness 7151366
The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK 715-1366 or is a Dorman 46004.
Vac harness 7151365
The tube from the rear of the valve cover to the intake manifold is part number BK 715-1365 or Dorman 46005 and comes with the valve cover grommet.
The Throttle Body to MAP hose is no longer available. Click HERE to access a fix for that.
Vac Diagram 4.0 Renix
