ratty Posted July 2, 2021 Share Posted July 2, 2021 Hey again. My air vent stopped working. It also doesn’t work on heat or ac. It does work on defrost. Thanks in advance. Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2021 Share Posted July 2, 2021 chances are that's a vacuum leak in the system. the defrost is the default position of the diverter door. Link to comment Share on other sites More sharing options...
ratty Posted July 2, 2021 Author Share Posted July 2, 2021 9 minutes ago, Pete M said: chances are that's a vacuum leak in the system. the defrost is the default position of the diverter door. Ok cool. Where would I find the hoses for all of that? Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2021 Share Posted July 2, 2021 the most common failure is the hose running into the Vacuum reservoir in the front bumper on the pass side. it's a black plastic ball or football. but it could be just about any vacuum line. how's the idle of the engine? Link to comment Share on other sites More sharing options...
ratty Posted July 2, 2021 Author Share Posted July 2, 2021 6 minutes ago, Pete M said: the most common failure is the hose running into the Vacuum reservoir in the front bumper on the pass side. it's a black plastic ball or football. but it could be just about any vacuum line. how's the idle of the engine? Good to know. The idle is great Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2021 Share Posted July 4, 2021 Link to comment Share on other sites More sharing options...
ratty Posted July 5, 2021 Author Share Posted July 5, 2021 On 7/4/2021 at 6:43 AM, cruiser54 said: This is great! Thank you Link to comment Share on other sites More sharing options...
jeepmjga Posted July 8, 2021 Share Posted July 8, 2021 Like they said prob a vaccuum leak. Follow the line from the canister to the line going into the firewall. Look for a red line, might be pink or white depending on how faded it is. Link to comment Share on other sites More sharing options...
All around mj Posted July 9, 2021 Share Posted July 9, 2021 You might also check the elbows to your vacuum lines and make sure they aren’t pushed down so far to create a blockage in your vacuum system. That’s what ended up happening to mine. Link to comment Share on other sites More sharing options...
ratty Posted July 30, 2021 Author Share Posted July 30, 2021 On 7/8/2021 at 8:18 PM, All around mj said: You might also check the elbows to your vacuum lines and make sure they aren’t pushed down so far to create a blockage in your vacuum system. That’s what ended up happening to mine. Seems like all my hoses are fine. I think it might be behind the dash now. Maybe my vent doors are stuck or the controls aren’t working. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 30, 2021 Share Posted July 30, 2021 Highly unlikely. Can you feel good vacuum where the hose goes from the engine bay to cabin? Link to comment Share on other sites More sharing options...
ratty Posted July 31, 2021 Author Share Posted July 31, 2021 On 7/29/2021 at 7:46 PM, cruiser54 said: Highly unlikely. Can you feel good vacuum where the hose goes from the engine bay to cabin? I found it! It was a tiny crack in a grey vacuum hose that goes into the firewall. Crazy Link to comment Share on other sites More sharing options...
cruiser54 Posted July 31, 2021 Share Posted July 31, 2021 Nice job. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 31, 2021 Share Posted July 31, 2021 Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2021 Share Posted July 31, 2021 Link to comment Share on other sites More sharing options...
ratty Posted August 1, 2021 Author Share Posted August 1, 2021 5 hours ago, cruiser54 said: Nice job. Thanks for your help. I appreciate it Link to comment Share on other sites More sharing options...
