70barracuda Posted May 23, 2021 Share Posted May 23, 2021 Just like the title says, does anyone know the stock stroke for the clutch master? I know the bores are .688 to .699 but I cannot find anywhere the stroke length. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 25, 2021 Share Posted May 25, 2021 I know I was able to use a wilwood clutch MC and it worked fine with the stock slave cylinder. Hopefully that helps somewhat Link to comment Share on other sites More sharing options...
70barracuda Posted June 15, 2021 Author Share Posted June 15, 2021 On 5/25/2021 at 9:48 AM, ghetdjc320 said: I know I was able to use a wilwood clutch MC and it worked fine with the stock slave cylinder. Hopefully that helps somewhat just saw this now. I did end up using a wilwood and it fit perfectly. Thanks Link to comment Share on other sites More sharing options...
ghetdjc320 Posted June 15, 2021 Share Posted June 15, 2021 5 minutes ago, 70barracuda said: just saw this now. I did end up using a wilwood and it fit perfectly. Thanks Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 15, 2021 Share Posted June 15, 2021 Has this wilwood setup make a noticeable difference 🤔 Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 15, 2021 Share Posted June 15, 2021 I just got off the phone with Quickdraw......... The question is- will this bell fit other Tremic transmissions? The question is unanswered but they will look into it. I believe the Tremic in question here will also fit the bell. Internals suck, yours will fail at some point, they all do. To answer the question, the Mopar master will work with the aftermarket internal slaves, Silver Sport uses Mopar masters and sells with their kit the hose and adapter to retain the Mopar master. Quickdraw maintains the Mopar master and external slave.......not necessarily the sole reason I'm going with Quickdraw but the primary one. The secondary reason is that I'm doing everything to avoid Novak and Advance Adapters......may even make my own engine mounts. If you want to maintain your existing Mopar unit......see here- https://quickdrawbrand.com/product/bell-housing-adapter-kit-for-the-chevy-ls-bbc-sbc-to-tremec-tr-4050/ Side note: I'm a fan of Wilwood and I'm not in anyway suggesting that you should not use Wilwood. What I am suggesting is that the Mopar external system is far superior to any aftermarket internal system. Link to comment Share on other sites More sharing options...
