Dzimm Posted May 10, 2021 Posted May 10, 2021 I know there has been topics in the past on bent gates but I haven't seen one this bad before and I haven't heard mention of how to get the gate off when you can't open it.. This is the gate on SMJ #96 and the top is bent so far in it is almost pinched at the top. I can't get it open currently, its so wedged that I can't even move the handle. Anyone run into this before and been able to get it open successfully? Then the next question is, how hard is it to separate the inner and outer skin of the gate to beat the metal back straight?
89 MJ Posted May 10, 2021 Posted May 10, 2021 @ghetdjc320 separated the inner and outer tailgate pieces. I’d try pulling the handle and just actuating the levers inside the gate if you can.
Dzimm Posted May 10, 2021 Author Posted May 10, 2021 7 minutes ago, 89 MJ said: @ghetdjc320 separated the inner and outer tailgate pieces. I’d try pulling the handle and just actuating the levers inside the gate if you can. How much pulling do you think the handle can take? I don't really want to breaker the handle or guys prying or pulling on it. I suppose regardless I've got to get something to move or it will never open.
89 MJ Posted May 10, 2021 Posted May 10, 2021 8 minutes ago, Dzimm said: How much pulling do you think the handle can take? I don't really want to breaker the handle or guys prying or pulling on it. I suppose regardless I've got to get something to move or it will never open. I meant remove the handle when I said pull the handle. What I should have said was remove the handle and try actuating the levers from the inside.
ghetdjc320 Posted May 10, 2021 Posted May 10, 2021 Checkout my them read on separating the shells. Pulling in the handle won’t help since it’s bolted to the inner panel
89 MJ Posted May 10, 2021 Posted May 10, 2021 The reason I’m suggesting removing the handle is in case the rods or even the tailgate shell if binding up on it and preventing it from moving.
ghetdjc320 Posted May 10, 2021 Posted May 10, 2021 https://comancheclub.com/topic/65482-tailgate-straightening/?tab=comments#comment-681767
Dzimm Posted May 10, 2021 Author Posted May 10, 2021 Just now, ghetdjc320 said: https://comancheclub.com/topic/65482-tailgate-straightening/?tab=comments#comment-681767 Thanks! That's definitely helpful. Not as bad as I'd imagine to separate. 6 minutes ago, 89 MJ said: The reason I’m suggesting removing the handle is in case the rods or even the tailgate shell if binding up on it and preventing it from moving. I may do that as well, seeing the inside of the gate thanks to ghetdjc320's thread I can at least visualize what's going on in there. I'm guessing the rod on the right side of the gate is probably pinched, I may have to yank on it with some pliers or pry the gate apart a bit with a long screwdriver through the handle hole to get some clearance for the rod to move. We shall see once I get a chance to tear into it.
Jesse J Posted May 10, 2021 Posted May 10, 2021 My mind goes to take a bfh and smack the back to get it straight enough it pops out
ghetdjc320 Posted May 10, 2021 Posted May 10, 2021 8 hours ago, Jesse J said: My mind goes to take a bfh and smack the back to get it straight enough it pops out That’s pretty much what I did once I got the shells apart. Just used a hammer and dolly all the way around.
