Lower Control Arm bracket (now with pics)
Went wheeling today and bent the passenger side lower control arm bracket where is the best/cheapest place to get them from. Or does some one have a set they would sell I need them within 2 weeks. I have a local run coming up and need to get this fixed.
Thanks
I ripped a LCA mount off my TJ's D30 & a local shop replaced it. I thought it was a Rubicon Express part & it was strong. Basically a chunk of 3/16 wall square tube cut to shape with a bolt hole in it. I had them skidplate the other LCA mount & box the pass. side upper mount right away. That is how the factory SHOULD have built'em.
Yeah my thought was/is to take all the factory stuff off and put on some kind of after market set up :popcorn:
I will have to get pics of this today.
All I can say is the MJ and the skinny pedal went together yesterday. :roll:
I have been doing some searching and surfing here is what I came up with so far.
Jeep combo bracket upgrade kit
http://ballisticfabrication.3dcartstore ... -1542.html
Lower Control arm skid plate wright up
http://www.members.shaw.ca/mcghee.kevin ... plates.htm
Ok guys Rusty’s have a set for 60 or Rubicon has them for I think they were 40 or 50 a piece.
So do I try to go with Rustys. And here is the thing they have one with a slotted hole and then they have there Jeep speed with a regular whole which one should I get.
Rusty’s Jeep Speed:
http://rustysoffroad.com/mm5/merchant.m ... gory_Code=
Heavy Duty Lower Axle Mounts: (slotted whole)
thats the plan BMP had a new rubicon upper mount. And the lower mounts will be coming from some place I am lean toward T and T Customs. I can get a set for 40 shipped for 10. So that will put me at 70 total for parts so under a 100 and this thing should be back under my truck.
Just be sure to box the upper mount and put skids on the lower mounts.
Here's a few Jeep speed mount pictures. They use some nice brace work and shock mounts.
Image Not Found
Image Not Found
Image Not Found
Image Not Found
