  • Replies 82
Pretty much just been tinkering with all the little stuff the last couple weeks. Lots of general cleaning up and zip tying stuff out of the way. Took a few photos of the engine bay all finished up as well as of the finished exhaust installed. Only things really left are the plug for the VSS and the computer flashing. Had a “buddy” that was supposed to do it for me for the cost of the credits then he changed that so I sent it off to Brendan at LT1Swap who is going to do it for $75
Got my computer back today! Put it back in and went to fire it up and the junky imported fuel rails leaked at every fitting no matter what I tried…. I broke down and ordered nice Holley ones from Summit Racing because I don’t want a fire hazard that I can’t trust. They’ll be in early next week hopefully
Well I got the fuel rails on it which was a pain. None of the brackets would work with this intake so I had to make them work. It now doesn’t leak and I cranked it up but it won’t really idle at all. It’s probably going to get pushed in the corner for a while and maybe I’ll get back to it later. Not resealing the oil pan and rear main is biting me as it’s leaking oil pretty bad and the power steering pulley isn’t going to work as the belt is trying to walk off. I’m pretty sure the idle issue is related to the MAF but I’m not an ls guy so I’m unsure. Also really not happy with this intake. I’m very close to putting a rebuilt 4.0 back in it as I have one on a stand ready to go
Well the 5.3 will live another day in this truck. After fighting with it for about a week I have it running and idling much better. I changed the power steering pulley to the corvette one and changed the spacers on the tensioner which seemed to fix the belt for now. Swapped the throttle body out to the oem 3 bolt with an ict billet adapter which I thought would fix the issues but it did not. Put a new Delphi crank sensor in as well which also did not really help. Finally got a cheap smoke machine and found quite a few large vacuum leaks. The crappy paper gaskets did not have enough give to seal so I swapped to oem style metal and rubber ones which fixed one leak. The next was this dumb intake has a plate on top to cover a hole but had no gasket at all which was another leak. I also had one at the extra MAP port so drilled and tapped that for a bolt. I had to wrap a few other bolts like the ones for the throttle body with tape to get them to not leak. I also added in a cold air intake and moved the MAF sensor farther from the throttle body and redesigned my throttle cable bracket hopefully I can pull it out tomorrow and go on a little test drive
