Crewmanche VIDEO
Dzimm
I just came across this video.  It's an outsider perspective on offroading but features a Crewmanche.  I have never seen a video of one nor have I seen this one in particular before.  Its a good watch.
yeah I was also about 9 months ago was looking at the jeepxj subreddit and it said if it's an xj or mj it belongs here and I thought they meant the grand cherokee with my brain that hadn't been enlightened so I look up jeep mj and saw comanches and was like ohh cool that might be fun to have
Mud is fun.
Until you have to clean and maintain the vehicle you drive in it.
Mud gets into everything.  It is murder on seals.  It will sneak into your diffs and you need to clean it out.  It finds it's way inside the frame and stays there along with all the moisture so it promotes rust.  It can even get into your transfer case, transmission, and engine.
I like driving someone else's truck in mud.
you've not lived until you're taking apart your drums in the parking lot so as to clean the mud outta them.  :doh:   that giant fire extinguisher you may see in my bed isn't for fires (although it'll do that job too).
not all mud is the same.  thick chunky mud is my favorite.  wet, drippy mud gets into everything.  clay mud dries hard as concrete and needs to be cleaned off quickly.  :fistshake2:
I'm not really a fan of pure mud.  only did that once, got bored with it fast.  I like when a bit of water makes a boring forest trail into something challenging. :D
