Manche' Boi Posted April 2, 2021 Share Posted April 2, 2021 Hey lads, Sooo my internal slave want out again after only 7 months since I last replaced it. I'm itching to ditch the pugeuot for an ax15 with an external slave but I don't really want to drop $1500 or so to get a brand new one right now. Has anybody ever looked into a bell housing swap to convert the internal slave into an external? I've seen some bell housings for like $200 or $300 on ebay. I don't know if they will bolt directly to my pugeot or if I'd need an adapter plate. Anyway I'm not sure if this is a viable solution but it is within my price range and when I eventually buy an ax15 I'll have the right bell housing for it. Thoughts? Thanks. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted April 3, 2021 Share Posted April 3, 2021 car-part.com Find a used 1994+ AX-15 in your area. Buy the bushing, master + line + slave combo. Install. Never look back. I did mine, all in, for ~$550-600. Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 3, 2021 Share Posted April 3, 2021 yeah hold off on doing much swapping with that puke yet. search for ax-15 to swap in. Link to comment Share on other sites More sharing options...
87MJTIM Posted April 3, 2021 Share Posted April 3, 2021 There are no bell housings for a BA10 to go external. Your options are to keep swapping slave cylinders or swap transmissions. Ask me how I know. Link to comment Share on other sites More sharing options...
omega_rugal Posted April 3, 2021 Share Posted April 3, 2021 3 hours ago, 87MJTIM said: There are no bell housings for a BA10 to go external. Your options are to keep swapping slave cylinders or swap transmissions. Ask me how I know. after some research i found that the BA10/5 has relatives that use external slave, volvos and of course, peugeots have them, but if you happend to find one it would be a miracle Link to comment Share on other sites More sharing options...
87MJTIM Posted April 3, 2021 Share Posted April 3, 2021 6 minutes ago, omega_rugal said: after some research i found that the BA10/5 has relatives that use external slave, volvos and of course, peugeots have them, but if you happend to find one it would be a miracle Would those bellhousing bolt up to a 4.0? Link to comment Share on other sites More sharing options...
omega_rugal Posted April 3, 2021 Share Posted April 3, 2021 check this thread Link to comment Share on other sites More sharing options...
