Can some one tell me if there were more than 2 grill header designs between 1987 and 1996. When i painted my MJ last year i switched to a 91-96 style header wanting to put a chrome grill and H/L doors. Now i can't find H/L doors that fit. Bought new ones made by Crown, There crap and don't fit, drove 200 miles to a pick a part in Albuquerque found orig OEM H/L doors  and they don't fit either All screw holes are 1/4" plus off. The header came off a 1992 cherokee its OEM and definitely not the same as my 88 header i took off.  Is there another header design after 1991. I do not see any other choices from part retailers. Thanks Paul
Here are the two different headers/headlight bezels. You can make the later bezels work with the earlier panel. You have to cut the top and bottom metal strips and do some other surgery. Red bezel 86-90 Black 81-92. Grille is also different. Basically the top and bottom metal strips on the earlier header were replaced with plastic on the 91 and 92 an integrated into the grille and bezel.
5 hours ago, eaglescout526 said:
84
Also late 86-90 XJW’s had the quad headlights.
Yeah, I was thinking Renix 4.0 years and ignoring the other engines :peep:
