JStone Posted February 17, 2021 Share Posted February 17, 2021 1990, Comanche sport truck! 2.5 L ax-4 with I believe the Dana 35 Rwd with 86” wheelbase. really new to this forum! But I’ve got tons to do to her! And I will be around here and there in the club. I couldn’t believe the original warranty guide came with it! Link to comment Share on other sites More sharing options...
Comunchy Posted February 17, 2021 Share Posted February 17, 2021 This is sweet. I picked up an original warranty guide and owners manual for my year as well. Very cool that your truck still had that little time capsule with it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 17, 2021 Share Posted February 17, 2021 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 4HA Special Scheduling Condition I 5KK First American Title Insurance CO. ALA ALK APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN DMD 3.55 Rear Axle Ratio DRJ Dana 35 Wide Rear Axle EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RA8 Delete Radio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 4/17/90 Body code TL61 Sold by WILLS MOTOR CO, TWIN FALLS ID Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 14 hours ago, eaglescout526 said: *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 4HA Special Scheduling Condition I 5KK First American Title Insurance CO. ALA ALK APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN DMD 3.55 Rear Axle Ratio DRJ Dana 35 Wide Rear Axle EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RA8 Delete Radio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 4/17/90 Body code TL61 Sold by WILLS MOTOR CO, TWIN FALLS ID Eagle Scout. You are the man, thanks for your tips and knowledge I’ll be using them ! I do have a question now! My brake fluid is pretty dark, and my E brakes are not exactly top notch. My rear end looks like it may have a leak, I’ll attach a photo! Do you think it’s worth it do do a disc install on the back? And what kind of headache am I going to give myself? Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 17, 2021 Share Posted February 17, 2021 No problem! You could do a disk conversion but honestly you’ll still have the issue of brake fluid going black at some point which means something is eroding away in the lines. You could just bleed them until clean fluid and watch the fluid for it to turn black quickly. the E-brakes are based on adjustment in the equalizer(in front of the gas tank) and the life on the shoes in the drum brakes. looks like that rubber plug is leaking and not so much the diff. Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 You’ve got a good point, hoping some TLC will help the brake lines last a bit longer, I’ll also do some digging into adjusting that equalizer, see if I can snug it up. are those rubber plugs pretty replaceable? Link to comment Share on other sites More sharing options...
Pete M Posted February 17, 2021 Share Posted February 17, 2021 the link in my signature has the method for factory brake bleeding. it's different than most cars so you have to do all teh steps or you won't get all the old fluid out. also in there should be links to the disk brake conversion Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 1 minute ago, Pete M said: the link in my signature has the method for factory brake bleeding. it's different than most cars so you have to do all the steps or you won't get all the old fluid out. also in there should be links to the disk brake conversion Righteous, will git r dunnn hopefully this weekend 🤘🏽 Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 17, 2021 Share Posted February 17, 2021 Back in the day there was a special tool to help with adjusting the E brake equalizer. I actually have it but it’s kinda a trial and error thing where if the truck rolls backwards after one adjustment, you’ll keep tightening till it stops. But check your drum shoes, they might be worn. Link to comment Share on other sites More sharing options...
89 MJ Posted February 17, 2021 Share Posted February 17, 2021 I think you should step back and decide what you want this truck to look like long term. We can help advise you from there. If you are going to do anything except keep the truck bone stock, or very close to it, then you should be looking at upgrading your whole axle. If you want to lift it and add big tires, you will need to change your brake lines anyways. Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 1 hour ago, 89 MJ said: I think you should step back and decide what you want this truck to look like long term. We can help advise you from there. If you are going to do anything except keep the truck bone stock, or very close to it, then you should be looking at upgrading your whole axle. If you want to lift it and add big tires, you will need to change your brake lines anyways. Too true, I do have lots I would like to try to do with this beaut, including a 2.5 or 3'' lift. I just run into the dilemma of timing and priority. Seeing my brake fluid being that dark threw some red flags so I figured start with the simpler nessecary repairs then move up to the big boy upgrades. Ill probably do a flush of the lines, then check my options. On a less then 3" lift do you have to extend the brake lines? and if I'm going to do this in the future, ( I read a ton about the rear axle swap and the 8.8 being one of the simpler). Do any of you have this done on yours? worth the battle? Link to comment Share on other sites More sharing options...
89 MJ Posted February 17, 2021 Share Posted February 17, 2021 I do have the 8.8 swapped into my truck. I used one out of an Explorer Sport Trac, so it was about an inch wider than a regular 8.8 and has drums. It was very worth it because I upgraded gearing while I was at it. No brake line extension is necessary with 3” or lift. You could probably do an 8.8 swap in a weekend if you had all of the parts already. Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 21 minutes ago, 89 MJ said: I do have the 8.8 swapped into my truck. I used one out of an Explorer Sport Trac, so it was about an inch wider than a regular 8.8 and has drums. It was very worth it because I upgraded gearing while I was at it. No brake line extension is necessary with 3” or lift. You could probably do an 8.8 swap in a weekend if you had all of the parts already. No joke eh? Well that gives me hope, ill have to dive in a ton into the gearing cause I just don't know enough about it. Why is the gearing such an upgrade? Link to comment Share on other sites More sharing options...
Pete M Posted February 17, 2021 Share Posted February 17, 2021 bigger tires make your engine work harder and it'll feel like you lost horsepower. lower gear ratios (higher numerically) give a mechanical advantage back to the engine. finding the right ratio for your tire/trans/engine combo can give your Jeep quite the kick in the pant when it comes to acceleration. Link to comment Share on other sites More sharing options...
89 MJ Posted February 17, 2021 Share Posted February 17, 2021 3 hours ago, JStone said: No joke eh? Well that gives me hope, ill have to dive in a ton into the gearing cause I just don't know enough about it. Why is the gearing such an upgrade? What Pete said. If you are doing a 3” lift, you will probably be running 31” tall tires. You will want 4.10 gears then. Link to comment Share on other sites More sharing options...
JStone Posted February 17, 2021 Author Share Posted February 17, 2021 45 minutes ago, 89 MJ said: What Pete said. If you are doing a 3” lift, you will probably be running 31” tall tires. You will want 4.10 gears then. Thanks guys! Appreciate the insight Link to comment Share on other sites More sharing options...
89 MJ Posted February 17, 2021 Share Posted February 17, 2021 59 minutes ago, JStone said: Thanks guys! Appreciate the insight Happy to help. You look like another young guy. Are you high school or college age? Link to comment Share on other sites More sharing options...
Pete M Posted February 18, 2021 Share Posted February 18, 2021 with 31s he's going to want 4.56 at least. 4.10 was stock with 27" tires. whatever you do, don't regear a dana 35. Link to comment Share on other sites More sharing options...
JStone Posted February 18, 2021 Author Share Posted February 18, 2021 1 hour ago, 89 MJ said: Happy to help. You look like another young guy. Are you high school or college age? 25 out of Trusty Rusty Salt Lake City Link to comment Share on other sites More sharing options...
JStone Posted March 1, 2021 Author Share Posted March 1, 2021 On 2/17/2021 at 11:27 AM, 89 MJ said: I do have the 8.8 swapped into my truck. I used one out of an Explorer Sport Trac, so it was about an inch wider than a regular 8.8 and has drums. It was very worth it because I upgraded gearing while I was at it. No brake line extension is necessary with 3” or lift. You could probably do an 8.8 swap in a weekend if you had all of the parts already. Okay so follow up question for the fellas.. Lookin at the future for my rear axel, i've seen the replacement of the 8.8 a dozen times now and put a ton of logistical thoughts into it. I just don't know that I have the resources and machines to get it all done, let alone without making a huge mistakes. So I'm wondering if I were to have it professionally done, does anyone have insight to what new styles or manufactures would be best? Link to comment Share on other sites More sharing options...
89 MJ Posted March 2, 2021 Share Posted March 2, 2021 1 hour ago, JStone said: Okay so follow up question for the fellas.. Lookin at the future for my rear axel, i've seen the replacement of the 8.8 a dozen times now and put a ton of logistical thoughts into it. I just don't know that I have the resources and machines to get it all done, let alone without making a huge mistakes. So I'm wondering if I were to have it professionally done, does anyone have insight to what new styles or manufactures would be best? I do not. That would be a question to put in tech. Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2021 Share Posted March 2, 2021 indeed. more eyeballs will see it. I've never paid for that. and I would get a Libby 8.25 myself Link to comment Share on other sites More sharing options...
