rylee144 Posted February 4, 2021 Share Posted February 4, 2021 I'm installing an ax15. This thin plate in dinged up so I'd like a new one. I'm going to order a new seal too. Link to comment Share on other sites More sharing options...
Jesse J Posted February 4, 2021 Share Posted February 4, 2021 this is a cork gasket but it seems right https://www.quadratec.com/products/52152_04.htm Link to comment Share on other sites More sharing options...
rylee144 Posted February 4, 2021 Author Share Posted February 4, 2021 Ya I saw that. I need the metal plate Link to comment Share on other sites More sharing options...
Jesse J Posted February 4, 2021 Share Posted February 4, 2021 It might of had a metal plate as like a gasket replacement. that's where my mind when at least. in all the expansions there isnt a plate Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 4, 2021 Share Posted February 4, 2021 Not seeing it in the catalog. Link to comment Share on other sites More sharing options...
rylee144 Posted February 4, 2021 Author Share Posted February 4, 2021 Guess I'll just use this one. Thanks for checking Link to comment Share on other sites More sharing options...
rylee144 Posted February 18, 2021 Author Share Posted February 18, 2021 This gromet peice plugs into the bell housing. I'd like a new one. Is this it? https://www.morris4x4center.com/crown-clutch-timing-probe-grommet-sold-individually-53006010.html?gclid=CjwKCAiAmrOBBhA0EiwArn3mfCs9H5c9qQzpD0eKbB5yrI5WVwuwEzp_JArl_AXmwQloXXd-QTUwBRoCFDYQAvD_BwE Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 18, 2021 Share Posted February 18, 2021 That one may or may not work. It says that part number is good for 91 and up XJ's, ZJ's and YJ's. Link to comment Share on other sites More sharing options...
rylee144 Posted February 18, 2021 Author Share Posted February 18, 2021 Itll be going in a external slave ax15 so prolly 94 and newer. Ought to work then. Thanks! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 On 2/5/2021 at 4:55 AM, rylee144 said: I'm installing an ax15. This thin plate in dinged up so I'd like a new one. I'm going to order a new seal too. I’ve never seen one of those before on an ax15. I can’t tell for sure but it looks like an angled piece to adjust how the shifter base sits. It may be part of the shifter you have instead of the transmission. ??? Link to comment Share on other sites More sharing options...
rylee144 Posted February 19, 2021 Author Share Posted February 19, 2021 I suppose that's possible. I'll have to take a look. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 16 minutes ago, rylee144 said: I suppose that's possible. I'll have to take a look. You know what, I think I do remember that piece. The transmission vents from the gear shift tower and I believe that metal piece is an oil splash guard to keep oil from slinging up into that vent in the shift tower. I believe it can be left off with no I’ll consequences. Link to comment Share on other sites More sharing options...
