CGCWO Posted February 3, 2021 Share Posted February 3, 2021 Doing some work under the drivers side of the dash and found these two wire connections. Any ideas what they are for? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted February 3, 2021 Share Posted February 3, 2021 Speakers iirc Link to comment Share on other sites More sharing options...
CGCWO Posted February 3, 2021 Author Share Posted February 3, 2021 May be, I was also thinking could be connector for floor board lights. Found the same wires on the 86 with a connector cover. Link to comment Share on other sites More sharing options...
Minuit Posted February 3, 2021 Share Posted February 3, 2021 Pretty sure it's the floor light. If you've got a multimeter, you can check. For a floor light, one wire will have +12V at all times and a ground only when the door is open. If the ground goes away when you push the door switch in, it's for a light. That's about the right place for speaker wiring too, but none of the speaker wires should have two wires crimped in the same connector IIRC. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 3, 2021 Share Posted February 3, 2021 Yep I agree. Those are the floor courtesy lights Link to comment Share on other sites More sharing options...
CGCWO Posted February 4, 2021 Author Share Posted February 4, 2021 Checked with meter and constant 12v with door open. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 4, 2021 Share Posted February 4, 2021 Just now, CGCWO said: Checked with meter and constant 12v with door open. The door jamb switches are a ground trigger. Link to comment Share on other sites More sharing options...
CGCWO Posted February 4, 2021 Author Share Posted February 4, 2021 Question on door jamb switches ante the both the same? Went to replace them today and the old passenger side one only had one electrical connector tab. Is this correct? The new ones I ordered have two tabs on them. Link to comment Share on other sites More sharing options...
CGCWO Posted February 4, 2021 Author Share Posted February 4, 2021 6 minutes ago, ghetdjc320 said: The door jamb switches are a ground trigger. See above post, forgot to quote you. Link to comment Share on other sites More sharing options...
