Here is my Comanche
After searching for countless hours I finally stumbled across this new old stock set for an XJ. The fronts were missing one of the brackets and the hardware, but the rears had everything. I will be installing them this weekend. I plan to replicate the front bracket and I am going to attempt to use the rear brackets for the XJ using some inspiration I got from the many articles on this site. Here is the eye candy....
15 hours ago, C1111toro said:
One of the nuts for the mounting bracket on the front snapped off. It should be loads of fun getting the stud out to be able to use a new bolt.
yeah, those little studs are made of the worst metal ever. :(
  • Pete M changed the title to Here is my Comanche
4 minutes ago, C1111toro said:
Has anyone ever pressed one out or does it have to be drilled?
I think pressing them would probably destroy the bracket. If the stud has a flat head on it on the other side of it, you could use a grinder to grind the head smooth and then the stud would pretty much fall off.
