ghetdjc320 Posted January 26, 2021 Posted January 26, 2021 Trying to track down this molding. Took some detailed pics of it. Anyone have any ideas?
Torq_Shep Posted January 26, 2021 Posted January 26, 2021 https://www.exactseal.com/wp-content/uploads/2017/04/Small_P_Seal_Profiles.pdf Number 955 is the closest thing I can find to it. Might be worthwhile contacting the company and see if they have this? However, it does look like this might fall under P-Seal profile.
ghetdjc320 Posted January 27, 2021 Author Posted January 27, 2021 2 hours ago, Torq_Shep said: Is this one style or two different styles? It’s two different styles. The rubber one is the outer gasket at the slider and the u shaped felt goes on the track inside.
Torq_Shep Posted January 27, 2021 Posted January 27, 2021 This is the closest I can find to the felt trim. https://jjautofabrics.com/2151-universal-flexible-window-channel-3-8-wide-x-7-16-tall-sold-by-continuous-yard/ But we may end up SOL on the other part.
BeatCJ Posted January 27, 2021 Posted January 27, 2021 My 3 panel slider needs all new seals, too. I think will order the channel, and call the best glass place in town, see if they know of a good rubber seal.
Goose_XJ88 Posted February 28, 2022 Posted February 28, 2022 On 1/26/2021 at 2:23 AM, ghetdjc320 said: Trying to track down this molding. Took some detailed pics of it. Anyone have any ideas? Did you ever find a replacement for the felt? My slider seems loose when closed and rattles going down the road. I figured that a new felt will quiet the rattle.
ghetdjc320 Posted March 1, 2022 Author Posted March 1, 2022 7 hours ago, Goose_XJ88 said: Did you ever find a replacement for the felt? My slider seems loose when closed and rattles going down the road. I figured that a new felt will quiet the rattle. I just ended up replacing it with the CR Laurence window. Didn’t keep pursuing the replacement seals
ratrapp Posted March 4, 2022 Posted March 4, 2022 i went to order the cr laurence window and was disappointed that it showed unavailable at this time.did you get yours and how did it fit?
ghetdjc320 Posted March 4, 2022 Author Posted March 4, 2022 Yes I got mine. It’s a very different fit from the original but looks very good in the end. The CR Laurence screws in from the inside of the cab in a few areas. You have to really have a good clean window opening for it to sit flush in. The frame is aluminum and can bend a bit to fit nice and flush. The instruction only call for using butyl tape to seal it. That’s what I did at first but I had small leaks. I took it all back out and reinstalled it with urethane and didn’t have any leaks after even with the pressure washer. The CR Laurence unit looks a little bigger and has a larger opening than the 3 pane oem unit. It also eliminates the rubber trim around the oem unit. These guys seem to have it in stock: https://www.dkhardware.com/duo-vent-four-panel-slider-with-solar-glass-for-1986-1992-jeep-comanche-edv700s-product-43373.html
