1987 Comanche Shortbed "Sportruck"
Engine:                  4.0
Transmission:       BA10/5
Transfer Case:      N/A
Front Axle:            2wd axle
Rear Axle:             Dana 35
Color:                    Grey
Mileage:                122K
Bulid Date:            Unknown
This truck has lived a hard life being on fire multiple times, none of which were caused by me, it came to me with the airbox area comply charred. Every wire that runs under the airbox and in that area had been melted. A majority of the vacuum lines also were charred. The intake valve lifter on the 5th cylinder was stuck up causing zero compression on that cylinder. Despite all that, after rebuilding the entire fuel system because the truck sat since 2004 and taping up most of the wires I hit the key and it stumbled to life.
*X1
-H9
3LR
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GSC MIRROR - RIGHT BLACK
H5A
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
HW1
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
MWB SPORT BAR
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NMB ENGINE COOLING - STANDARD DUTY
PXJ
QXJ
SBA POWER STEERING
TBG SPARE TIRE - COMPACT
TBL TIRE CARRIER
WJM Wheels - 15 x 7.0 Chrome
Build date 2/17/87
Body code TL61
