ryanboh
Everything posted by ryanboh
  1. ryanboh
    1J7FJ36L7KL499808
    1989 Comanche Longbed 4WD Pioneer 4.0 Engine Automatic 126k miles Located in EZ Pull and Save, Ringgold, PA Dark Blue interior with bucket seats
  2. Yup it is a 207. I read the tag, and typed the wrong thing lol.
  3. 1986 Jeep Cherokee Chief Engine: 2.8 Transmission: AX5 Transfer Case: Np207 Front Axle: Dana 30 Rear Axle: Dana 35 Color: Red Mileage: 106K Location: Bloomsburg, PA Bulid Date: Unknown
  4. 1986 Jeep Cherokee Base Factory Turbo Diesel Engine: 2.1 Renault Transmission: AX5 Transfer Case: N/A Front Axle: 2wd axle Rear Axle: Dana 35 Color: White (currently tan) Mileage: 83k Location: Bloomsburg PA
  5. ryanboh
    1J7FJ36L5KL627477
    1989 Comanche Pioneer Shortbed 4WD 4.0 Engine 5-speed 208k miles Located in Bloomsburg,PA Features- currently broken in half parts truck. Has a Dana 44 rear
  6. ryanboh
    1J7FJ36L5KL612462
    1989 Comanche Shortbed 4WD 4.0 Engine Automatic 166k miles Located in EZ Pull and Save, Ringgold, PA Dark Blue interior with bucket seats
  7. ryanboh
    1JTMP63P4JT109519
    1988 Comanche Shortbed 4WD 4.0 Engine 4 speed automatic 163k miles Located in Harry's U Pull It, Hazelton PA
  8. ryanboh
    1J7GT26L2KL400109
    1989 Comanche Longbed 2WD 4.0 Engine 5-Speed 120k miles Located in EZ Pull and Save, Ringgold, PA Back glass had a sticker that said "Big Ton"
  9. ryanboh
    1JTML6510HT090580
    Very sad end to a Comanche 1987 Longbed 4.0 4x4 Mileage Unknown Factory bed liner still installed Location : Madison Salvage & Recycling in Bloomsburg PA
  10. ryanboh
    1JTMW6419HT111998
    1987 Comanche Shortbed "Sportruck" Engine: 4.0 Transmission: BA10/5 Transfer Case: N/A Front Axle: 2wd axle Rear Axle: Dana 35 Color: Grey Mileage: 122K Location: Bloomsburg, PA Bulid Date: Unknown This truck has lived a hard life being on fire multiple times, none of which were caused by me, it came to me with the airbox area comply charred. Every wire that runs under the airbox and in that area had been melted. A majority of the vacuum lines also were charred. The intake valve lifter on the 5th cylinder was stuck up causing zero compression on that cylinder. Despite all that, after rebuilding the entire fuel system because the truck sat since 2004 and taping up most of the wires I hit the key and it stumbled to life.
  11. ryanboh
    1JTWL657XGT019799
    1986 Comanche longbed X Engine: 2.8 Transmission: AX5 Transfer Case: Np231 Front Axle: Dana 30 Rear Axle: Dana 35 Color: Grey Mileage: 169K Location: Bloomsburg PA Bulid Date: Unknown
  12. ryanboh
    1J7FJ26S4NL194109
    1992 Comanche Sport Short Box 4X4 Engine: 4.0 Transmission: AW30-43LE Transfer Case: Np231 Front Axle: Dana 30 with limited slip Rear Axle: Dana 35 with ARB air locker Color: White Mileage: 117k Location: Bloomsburg PA Bulid Date: Unknown Extra Stuff: This truck was my highschool daily and currently my college vehicle. It has a trail master 4in lift as well as 32in Goodyear wranglers. It has a SWB rollbar with a outlaw light bar. It was purchased from the second owner who also used it as his daily.
  13. ryanboh
    1JTMP63P2JT162848
    1988 Comanche Pioneer Short Box 4X4 Engine: 4.0L Renix Transmission: AW30-40LE Transfer Case: Np231 Front Axle: Dana 30 Rear Axle: Dana 35 Color: Colorado Red Mileage: 214k Location: Bloomsburg PA Bulid Date: March 15 1988 Extra: It was pulled from a cemetery barn which it had been sitting there since 1999. It was used as a hearse for the cemetery to get the caskets into the harder to reach areas. Also still had half of the bulid sheet under the driver side seat.
