1JFT26S0ML546868
moparbrown
1991 Jeep Comanche: Manual Short bed 2x4
As of Dec/2020 (Red is bondo, hopefully paint soon!)
4.0L I6 Power Tech Engine/ 5-Speed Manual/ Stock Front axle? / Stock Rear axle?/ Rear Wheel Drive
Build date: 10/90
Current Location: United States, Missouri, St. Louis area
Status: Daily driver. 245k miles. Purchased from used car lot in Junction City Kansas and driven 5 hours home to St. Louis area. Traded straight across for used Dodge Charger with hail damage. Undergoing amateur home “restoration”. See Moparbrowns Manche for build updates.
https://r.tapatalk.com/shareLink/topic?share_fid=53169&share_tid=53308&url=https%3A%2F%2Fcomancheclub%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F53308-Moparbrowns-Manche&share_type=t&link_source=app
Notes: Seemed pretty much stock when purchased except floors had been patched and bench seat swapped out to buckets. No rear bumper when purchased, think it was that way from stock as it had the liscense plate light. Had square front off-road style lights on bumper not sure if stock. Short bed.
Black exterior paint, blue dash, light grey interior panels, black vinyl floor, 5-speed, bed mat (factory?). I have done basic repairs to keep it running and installed new bumpers front and rear plus KC spread lights.
Current owner: Dillon Brown
Link to build sheet: https://www.jeep.com/webselfservice/BuildSheetServlet?vin=1J7FT26S0ML546868
correct VIN: 1J7FT26S0ML546868
Pretty neat its a military sales
BUILD: 10/30/90
BODY: TL61
*D4 DESCRIPTION NOT AVAILABLE -SA Charcoal ALA
CBAP Straight Back Bench Seat CKJP Black Vinyl Floor Covering DBBC All Manual Transmissions
DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GEC Front Left Side Sliding Window
GRVP Left Manual Mirror JAY DO NOT USE - See JP, KA classes JGBP Digital Clock
JHA Var Intermittent Windshield Wipers MDAP Front License Plate Bracket PX8 Black Clear Coat
SBAA Power Steering SUA Tilt Steering Column TPF P205/75R15 BSW All Season Tires
TZHP Michelin Brand Tires WLYC All Steel Wheels YGAA Without Billable Fuel
Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z77P Right Front Spring Group VII
4FVP Assembly Plant Tracking 4HA Special Scheduling Condition I 8ED Miscellaneous Intl Dealers
APAS Monotone Paint BAPS 75 Amp Alternator BCXS Maint. Free Battery
BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DMMS 3.07 Rear Axle Ratio
DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass GUAS Open HCDS Do Not Use - See HCA
JCAS 85 MPH Primary Speedometer KDPS STRIPE/BADGE/MOLDING COLOR KWAS STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp
LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille
MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings
MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBKS EVAP Control System
NF2S 18.5 Gallon Fuel Tank QX8S Black Clear Coat RA8S Delete Radio
SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers
TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels
XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating
1AVS Export O.M.S.C. U.S. Specifications 105S Zone 05-Chrysler Military Sales
Thanks [mention]jdog [/mention]! That is pretty cool that it was military ordered. It makes sense since I got it from Junction City Kansas where Fort Riley is located (my brother was actually stationed there when I picked it up). Is that why it doesn’t specify “pioneer” or “eliminator”, etc?
Fun fact, I am exactly 5 days older than my truck.
that might be a reused code too.  even if it is, it'll still have a trim level of some kind. :L:  I went through and edited out the common wrong ones for ya.
5 hours ago, jdog said:
@moparbrown you are welcome, happy belated birthday to you and your truck. the build sheet won't tell me the trim level, the body code tells us its a low line short bed so base, or sportruck I believe @fiatslug87 might be able to assist on trim level
This is an Eliminator, the 6 in position six of the VIN designates that.
@jdog From '90 on the body code for Eliminators contained an "L", before that it was an "S".
My mistake, I did not see @jdog's updated VIN, the 6th position is a 2, therefore, a base.
  • 1 month later...
