JeepcoMJ Posted October 31, 2007 Share Posted October 31, 2007 np208 what's the value? I got one for $200 today cause I know it's worth more. haven't picked it up yet, but what's the spline count, and what the spline count of an ax5 is? it's out of an 81 fullsize. yes, it is driver's side drop. oh, and those of you who don't know...the np208 is a fixed yoke transfer-case. i.e. you don't need a slip-yoke eliminator for it. thinking of putting it in my xj...and plans for another 3800 conversion are now under way. Link to comment Share on other sites More sharing options...
feerocknok Posted October 31, 2007 Share Posted October 31, 2007 NP208 shouldn't be fixed yoke: And it's chain driven, but still strong. I'd say it's worth about what you paid and should do fine behind that 3.8 as far as power is concerned. I think yours'll be a 32 spline. Link to comment Share on other sites More sharing options...
feerocknok Posted October 31, 2007 Share Posted October 31, 2007 I think the only other spline count is 27. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 31, 2007 Author Share Posted October 31, 2007 it's a 1981 np208 from a fullsize wagoneer...it's fixed yoke. :D Link to comment Share on other sites More sharing options...
feerocknok Posted October 31, 2007 Share Posted October 31, 2007 Ah! I was looking at Chevies and was wondering how you got a driver's side drop. 1980-1988 DTS204-2 NP208J 23 Spline front input front and rear fixed yokes shift indicator located to the left side of shift 1.75" speedo hole, left hand mount New: $856.25 Core: $350.00 http://www.drivetrain.com/transfercaseappjeep.html Core's worth $350. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 31, 2007 Author Share Posted October 31, 2007 Core's worth $350. who just got a good buy? a-this guy! :brows: Link to comment Share on other sites More sharing options...
TNT Posted October 31, 2007 Share Posted October 31, 2007 So are you keeping it or trading it????? Link to comment Share on other sites More sharing options...
offroader461 Posted October 31, 2007 Share Posted October 31, 2007 i thought about it but decided not to only b/c you have to have a 23 spline trans due to the Np208 is 23splined and then have to fab up the linkage...around here they go for about $100 Link to comment Share on other sites More sharing options...
TNT Posted October 31, 2007 Share Posted October 31, 2007 Core's worth $350. who just got a good buy? a-this guy! :brows: There is one in Milwaukee for $145.00 and a couple others local for $200.00. I might know where to get one for $100.00. I picked up my HP D44 and 9" axle for $200.00 total. Maybe we can work a trade if you aren't keeping in. It is 23 spline and needs a spacer to fit becasuse of the longer input shaft. Link to comment Share on other sites More sharing options...
FxRacing282 Posted November 1, 2007 Share Posted November 1, 2007 its an aluminum case right? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 1, 2007 Author Share Posted November 1, 2007 yep aluminum case. spacer's not a problem, I can make one at burlington machine and tool (or have the owner make me one) I'll be keeping it and finding an ax15 to mate to it I know where a dodge dakota 2wd ax15 4 cyl is for cheap so I can get that bellhousing and find an ax15 elsewhere, put this on it, and that will instantly boost my drivetrain capability. this has become a race to parts accumulation :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 1, 2007 Author Share Posted November 1, 2007 truth be told I could probably get him to machine me a 21 spline shaft for it for less than $100 if I had to. Link to comment Share on other sites More sharing options...
carnuck Posted November 19, 2007 Share Posted November 19, 2007 I would get an AX-15 and the bellhousing from a 2.5L Dakota if you keep the 4 cyl. Then you need a spacer (Parts Mike has them for @$100) The Jeep NP208J (or AM on some tags) is 23 spline and fixed yoke, LH drop. Ford NP208 is 31 spline (also LH drop) but it's wider with a longer chain and thicker gears. They come fixed (full size Bronco to '88 with V8) or slipyoke (pickups) Chev only came RH drop with slipyoke and are 27 spline for TH350 and 700R4 or 32 spline for TH400 and 4L80E. (they also have nylon shifter forks which cause a lot of the bad reports for this tcase) Dodge are mirror image of the Jeep, but can be fixed (Ramcharger and Trailduster) or slipyoke (pickups) and are 23 spline only AFAIK. I happen to have one of each of the above for sale here in Seattle. I bought them all for comparisons (I planned on using the Dodge tcase before I rolled my '73 J4000) The Jeep or Dodge NP208 will bolt directly to the 904 4x4 trans (or a Jeep 727 4x4 trans) I was going to take the Chev 27 spline input and use it in a Jeep NP208 so I could bolt it directly to a 700R4 for overdrive. Link to comment Share on other sites More sharing options...
