Jesse J Posted December 14, 2020 Author Share Posted December 14, 2020 I am doing a complete rebuild when I get to 400,000 miles so I'd do it then was my thought. I'm gonna see how it runs and drives with a lift and tires to see if I need a boost. that 12 wheight crank might be nice anyways Link to comment Share on other sites More sharing options...
derf Posted December 14, 2020 Share Posted December 14, 2020 I'd agree. A stroker only makes sense when you're already rebuilding the engine. Especially if you're doing an over bore and have to buy pistons anyway. The incremental cost for the crank and the right pistons is small compared to the rest of the rebuild. But if you have an already good engine, a stroker is a big expense. I am planning an inexpensive stroker build when it's time for me to rebuild the engine. And that's on the near horizon for my XJ as I'm getting a rod knock. But my MJ engine is running fine so I'm going to leave it for a while. Link to comment Share on other sites More sharing options...
Jesse J Posted December 14, 2020 Author Share Posted December 14, 2020 Yeah exactly I'm already gonna pay a machine shop might as well have them balance a new crank while I'm at it Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 14, 2020 Share Posted December 14, 2020 3 hours ago, Jesse J said: Yeah exactly I'm already gonna pay a machine shop might as well have them balance a new crank while I'm at it If you scrap the idea that the 12cw is what you need then you can make the process a bit easier. But there is a lot involved still Link to comment Share on other sites More sharing options...
Jesse J Posted December 14, 2020 Author Share Posted December 14, 2020 4 minutes ago, ghetdjc320 said: If you scrap the idea that the 12cw is what you need then you can make the process a bit easier. But there is a lot involved still yeah Idk lots of options. it's gonna be a while before I do anything. my odo needs to say 400,000 before I do Link to comment Share on other sites More sharing options...
Car Enthusiast Posted December 16, 2020 Share Posted December 16, 2020 I second talking to Russ Potenger. He walked my through my 4.7 build from the start. Jeepstroker.com is also a good site to read through. I have over 20k miles on mine. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 16, 2020 Share Posted December 16, 2020 3 minutes ago, Car Enthusiast said: I second talking to Russ Potenger. He walked my through my 4.7 build from the start. Jeepstroker.com is also a good site to read through. I have over 20k miles on mine. Russ does some amazing work (best I’ve seen in the Jeep world) and can get you everything you need for a good price. Or he can build you a whole stroker engine. I’d put his builds above Hesco and Golen any day. Link to comment Share on other sites More sharing options...
Car Enthusiast Posted December 16, 2020 Share Posted December 16, 2020 Yeah he is awesome to deal with also, answered every question I had. Even through assembly. I had a local machine shop deck the block, magnaflux, balance everything. Then I assembled Link to comment Share on other sites More sharing options...
Car Enthusiast Posted December 16, 2020 Share Posted December 16, 2020 RussBnBracing@yahoo.com Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 16, 2020 Share Posted December 16, 2020 Wonder if we can convince Russ to jumó on the forum?? Link to comment Share on other sites More sharing options...
Jesse J Posted February 18, 2021 Author Share Posted February 18, 2021 what do the modifications to the 12 counterweight crank look like Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 18, 2021 Share Posted February 18, 2021 6 hours ago, Jesse J said: what do the modifications to the 12 counterweight crank look like What are your referring to? The 12cw went the way of the dinosaur and was replaced by the 4cw. Link to comment Share on other sites More sharing options...
Jesse J Posted February 19, 2021 Author Share Posted February 19, 2021 1 hour ago, ghetdjc320 said: What are your referring to? The 12cw went the way of the dinosaur and was replaced by the 4cw. well for the 4.2 crank the earlier ones had 12cw but those don't drop in like the later ones with lets cws because there is some modification right? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 8 minutes ago, Jesse J said: well for the 4.2 crank the earlier ones had 12cw but those don't drop in like the later ones with lets cws because there is some modification right? It was a few years that they ran the 12cw. The snouts on all pre 87 cranks are too long and need to either be cut down or have a spacer added to the crank. Just because they are rare doesn’t mean they are better though. A new scat crank will perform very well indeed as will the 87-90 YJ 4.2 crank. Let us know when you actually start building one though. Otherwise this is just theoretical. Link to comment Share on other sites More sharing options...
Jesse J Posted February 19, 2021 Author Share Posted February 19, 2021 Just now, ghetdjc320 said: It was a few years that they ran the 12cw. The snouts on all pre 87 cranks are too long and need to either be cut down or have a spacer added to the crank. Just because they are rare doesn’t mean they are better though. A new scat crank will perform very well indeed as will the 87-90 YJ 4.2 crank. Let us know when you actually start building one though. Otherwise this is just theoretical. ok. just eagle said probably would be better to go with a 12cw crank for better low end torque. and yes this is purely hypothetical because it is easy to change the plan now not when my engine is in pieces Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 Also, checkout the Jeepstrokers forum for some of these questions. There is a huge knowledge base specific to these engines and all of your questions have likely been answered there before. Link to comment Share on other sites More sharing options...
Jesse J Posted February 19, 2021 Author Share Posted February 19, 2021 oh smart I will definitely do that Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 Very good tech from some who have been doing this from the start. You’ll see some familiar faces there too from CC Link to comment Share on other sites More sharing options...
Jesse J Posted February 19, 2021 Author Share Posted February 19, 2021 kewl Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 19, 2021 Share Posted February 19, 2021 Link to comment Share on other sites More sharing options...
