Muncher Posted December 3, 2020 Posted December 3, 2020 Hi. I'm looking for a bench that has the head rests. Preferably someone rhat would be willing to take just the head rests and the peices that connect them to the seat frame off.
schardein Posted December 4, 2020 Posted December 4, 2020 16 hours ago, Muncher said: Hi. I'm looking for a bench that has the head rests. Preferably someone rhat would be willing to take just the head rests and the peices that connect them to the seat frame off. I have my 1991 bench seat disassembled right now, and I don't see anyway to remove the pieces that hold the headrest. The cushion is molded around the frame and can't be removed to access that area. The plastic inserts that the headrests slide into are hard to remove. In my experience, they usually break the retaining tabs when being removed, unless you cut into the seat (bucket seat) and actually depress the retaining tabs while you work them out. I don't see any way to do that with a bench seat unless you cut into the foam.
Muncher Posted December 4, 2020 Author Posted December 4, 2020 6 hours ago, schardein said: I have my 1991 bench seat disassembled right now, and I don't see anyway to remove the pieces that hold the headrest. The cushion is molded around the frame and can't be removed to access that area. The plastic inserts that the headrests slide into are hard to remove. In my experience, they usually break the retaining tabs when being removed, unless you cut into the seat (bucket seat) and actually depress the retaining tabs while you work them out. I don't see any way to do that with a bench seat unless you cut into the foam. Yeah I'm not sure if the cushion comes off or not without cutting. Pete said something about having the peice from a head rests bench and he was going to put it on his. Nkt sure if he had to cut the bench cushion open or not
Pete M Posted December 4, 2020 Posted December 4, 2020 I using the entire back frame (or at least that's the plan). I don't see any way to disassemble the frame any more. it's like the foam was molded right to it.
eaglescout526 Posted December 4, 2020 Posted December 4, 2020 Pete you are correct. Foam is molded to the upright frame. Also 90-92 is correct for the bench with head rests.
Muncher Posted December 4, 2020 Author Posted December 4, 2020 36 minutes ago, Pete M said: I using the entire back frame (or at least that's the plan). I don't see any way to disassemble the frame any more. it's like the foam was molded right to it. Ohhh ok. That makes more sense
