jdog Posted October 28, 2020 Posted October 28, 2020 style of window? 3 pane or 4? when does it squeak?
ratty Posted October 28, 2020 Author Posted October 28, 2020 8 minutes ago, jdog said: style of window? 3 pane or 4? when does it squeak? 3 pane. When driving. Mostly when there are little bumps
jdog Posted October 28, 2020 Posted October 28, 2020 open or closed? is it a high pitch, low pitch or like a rattle
ratty Posted October 28, 2020 Author Posted October 28, 2020 7 minutes ago, jdog said: open or closed? is it a high pitch, low pitch or like a rattle Closed or slightly open. It’s pretty high pitch
jdog Posted October 28, 2020 Posted October 28, 2020 any way you could post a video of it? at the moment i have no good answer
ratty Posted October 28, 2020 Author Posted October 28, 2020 59 minutes ago, jdog said: any way you could post a video of it? at the moment i have no good answer I could try, but not for a day or 2.
CaptainPatchy Posted November 1, 2020 Posted November 1, 2020 On 10/27/2020 at 10:52 PM, ratty said: Closed or slightly open. It’s pretty high pitch Mine does the something similar unless it's ALL the way open. I looked into it and was told the factory 1/8 felt around the rear sliding window wears out and replacing it will shut the squeaks up. Took it to a window place near my work, and was told they couldn't get the felt anymore! For now I just folded some tiny slips of paper and wedged them in between the panes to make it quiet, but in the future I'd like to get it fixed proper.
Dzimm Posted November 2, 2020 Posted November 2, 2020 I have the exact same problem. Usually just open the window all the way. When latched it doesn't always squeak but still does often enough to be annoying. I'd agree the felt is the likely cause. Should be able to find some replacement fairly easily, will be a DIY solution tho.
ratty Posted November 2, 2020 Author Posted November 2, 2020 22 hours ago, CaptainPatchy said: Mine does the something similar unless it's ALL the way open. I looked into it and was told the factory 1/8 felt around the rear sliding window wears out and replacing it will shut the squeaks up. Took it to a window place near my work, and was told they couldn't get the felt anymore! For now I just folded some tiny slips of paper and wedged them in between the panes to make it quiet, but in the future I'd like to get it fixed proper. 14 hours ago, Dzimm said: I have the exact same problem. Usually just open the window all the way. When latched it doesn't always squeak but still does often enough to be annoying. I'd agree the felt is the likely cause. Should be able to find some replacement fairly easily, will be a DIY solution tho. Good to know. I'll try and find something that will work!
gogmorgo Posted November 3, 2020 Posted November 3, 2020 I’ve noticed that my bucket seat squeaks when it’s back all the way. Either the seat or headrest contacts either the cab wall trim or the window. I just set the recline a little more upright so it wasn’t touching, and Bob’s your auntie. Of course that won’t help if the squeak is the slider rattling in it’s frame, but it’s worth a shot.
