VIN:1JTHS6415HT033197
Rubikahn
*X1
-YY
3LR
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DCB Transmission - 4-Speed Manual,T3340
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6
QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6
TBG SPARE TIRE - COMPACT
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
Build date 10/5/86
Body code TL61
1 hour ago, Rubikahn said:
Thank you for the build information.
your complete build sheet is much longer than what you see.  the early years have a lot of lost info that never got into Chrysler's computers. :(  (check the later MJ years and you'll see how long it should be)  but you might still have your original paper sheet in the truck!  common locations are inside the door panel, behind the rear carpet panel, stuffed under a seat or up under the pass side dash.
Sounds good, I will look in those locations and see if I get lucky.
  • 3 months later...
