Has anyone ever swapped a Cherokee dash and installed it into a Comanche chassis? I am having issues with the dash harness and not having enough pins. My brake lights originally didn’t work. Installed new light bulbs then checked the switch.using my test light I found that Cherokee side I have brake lights. Comanche side is pinned different and not sure if anyone else ran into this issue?
29 minutes ago, Redrover said:
Pin 11 has 2 wires going to it already. Does that matter?
2 wires already? ummm? better double check the pin connections again.
33 minutes ago, Redrover said:
Is the malfunction switch the brake switch?
no. be on the lower side of steering column  blinkers run though this as well as wipers.
