early comanche owner Posted October 5, 2020 Share Posted October 5, 2020 I found a consol and good seats from 96 to 2000 is all the guy told me and didnt know if seats were same bolt patter and if the console will fit without issue. thanks Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 5, 2020 Share Posted October 5, 2020 no. different floor pans you van make seats and console work but will need to fab up some brackets of some sorts. Link to comment Share on other sites More sharing options...
Pete M Posted October 5, 2020 Share Posted October 5, 2020 it's not a direct bolt-in per se, but it is an easy mod to gain cupholders edit: that applies to the console. seats require a bit more because of the 96+ floor differences Link to comment Share on other sites More sharing options...
boxyjeep Posted October 5, 2020 Share Posted October 5, 2020 Some very basic modifications to mount it. You can buy the steel XJ mounting bracket and bend the tabs a bit for Comanche. Also need to cut out the seatbelt mounting areas to get the bolts in. Also, the emergency brake mount needs to be figured out. Link to comment Share on other sites More sharing options...
jdog Posted October 5, 2020 Share Posted October 5, 2020 Seats require some mod, console has a different install bracket, but goes in fairly easy Link to comment Share on other sites More sharing options...
