Transmission not going into gear 1992 Jeep Comanche
So I have a question for you guys, I recently did a swap of my 2.5l to the 4.0.  I kept the automatic in it. I cannot get the truck to go into gear and actually move.  I replaced trans cooler lines. I made sure trans was full of fluid. Ran truck and checked fluid. Fluid level is fine. Checked shift linkage like I was reading and found nothing. I got to thinking, maybe there is air in the system that needs bled out. Anyone ever run into this issue? It don’t really stay in park very well either
  • Redrover changed the title to Transmission not going into gear 1992 Jeep Comanche
The rod that connects the bottom of the transfer case shifter to the mode selector on the TC is different between the different transmissions.  You didn't mention what your old transmission was bolted to the 2.5 you took out....the shortest of those connecting rods is for the AX4/5, middle sized is for the AX15, and the longest of them all fits the AW4.  If you had an AX trans and reused your original shift rod and connected it to an AW4 (I don't even think it's long enough to even get close to fitting) I'd bet your TC is not in the correct mode.
Another thought, if you did in fact have an AW4 bolted to your 2.5 (a rarity, but they do/did exist), it takes a different torque converter than an AW4 bolted to a 4.0L.
